Replace Cam Chain Tensioner
Posted: Tue Nov 07, 2017 1:37 am
by kiapolo1887
I need to change out my cam chain tensioner on my 2013 PCX 150. Does anyone have any instructions or a guide to accessing the cam chain tensioner?
Re: Replace Cam Chain Tensioner
Posted: Tue Nov 07, 2017 1:52 am
by kiapolo1887
It looks like I need to remove the throttle body to access the tensioner. Looking at page 10-8 of the service manual, do I need to drain the engine oil and/or coolant?
Posted: Tue Nov 07, 2017 6:01 am
by Gil
I didn't drain the coolant or oil. I remember removing the seat, under seat tub, maybe throttle body.
Check your oil level, mine was too high and I suspect that it's the reason that the chain tensioner broke.
Gil
Posted: Tue Nov 07, 2017 3:49 pm
Gil wrote:I didn't drain the coolant or oil. I remember removing the seat, under seat tub, maybe throttle body.
Gil
Why?
Posted: Tue Nov 07, 2017 9:54 pm
by Gil
I bought the scoot with a bad engine sound, after diagnosing the issue. My friend and I noticed that the oil level was too high, it had a fresh oil change when the tensioner broke. The engine had ~3/4 of a quart too much oil. My theory is that as the timing chain becomes more submerged in oil, it adds more stress to the chain tensioner, leading to its failure. All I have for my theory is the fresh excessive oil and broken chain tensioner.
Gil
Update: Replaced Cam Chain Tensioner
Posted: Sat Nov 11, 2017 11:23 pm
by kiapolo1887
Replaced the cam chain tensioner this morning. Start to finish took about an hour-and-a-half. First time taking off any body panels or the luggage box, so the going was relatively slow. Did not need to completely remove the throttle body, just disconnect from the intake pipe and move out of the way.
Thank you for all your help!
I'll make a post in "How-to" if anyone is interested.
Posted: Sun Nov 12, 2017 12:21 am
by Gil
That's great, i'm a sure the how to post will help someone.
Gil
Posted: Sun Nov 12, 2017 6:52 am
by Gil
How many miles on your PCX when the tensioner broke?
Gil
Posted: Sun Nov 12, 2017 10:57 am
Gil wrote:I bought the scoot with a bad engine sound, after diagnosing the issue. My friend and I noticed that the oil level was too high, it had a fresh oil change when the tensioner broke. The engine had ~3/4 of a quart too much oil. My theory is that as the timing chain becomes more submerged in oil, it adds more stress to the chain tensioner, leading to its failure. All I have for my theory is the fresh excessive oil and broken chain tensioner.
Gil
Fair enough if you think that was the reason in your case. Although I’m not sure you know the providence/history of the engine you are basing your opinion on. Did you know anything else about it other than it had too much oil and the tensioner was broken?
Re: Update: Replaced Cam Chain Tensioner
Posted: Sun Nov 12, 2017 11:45 am
kiapolo1887 wrote:Replaced the cam chain tensioner this morning. Start to finish took about an hour-and-a-half. First time taking off any body panels or the luggage box, so the going was relatively slow. Did not need to completely remove the throttle body, just disconnect from the intake pipe and move out of the way.
And a fine organized How-to it is! :P
See it here folks: http://www.hondapcx.org/viewtopic.php?f=3&t=8299
Thank you kiapolo for the step by step. Well Done!! ;)
Posted: Sun Nov 12, 2017 11:58 am
It was. Homie this is what I was talking about, an easy tub removal. OK it wasn’t removed but it’s what you used to do on old skool scooters to get at the engine/gubbins.
Posted: Sun Nov 12, 2017 12:26 pm
by kiapolo1887
Gil wrote:How many miles on your PCX when the tensioner broke?
Gil
Just over 10,000 miles.
Posted: Sun Nov 12, 2017 6:18 pm
by Gil
Gil
You are definitely right, it could be a countless number of other things. I'm just basing my theory on cause and effect. The scoot had 7600 miles of mostly city riding, according to the previous owner.
Gil
