The Honda PCX / Honda Forza Forums
Your predominant source of information for the Honda PCX 125, Honda PCX ESP, Honda PCX 150, and Forza 300. Now featuring a Forza 125 subforum!
It is currently Sat Apr 29, 2017 10:25 am
Post new topic Reply to topic  [ 15 posts ]
Author Message
 Post subject: rear tyre
PostPosted: Fri Mar 14, 2014 10:13 am
Offline
Just a little question? I've had my pcx one year, its done 4300 miles, the rear tyre looks worn! It has the irc 90/100x14 tyre on it, it feels smooth nearly slick down the centre. Does this tyre need changing?
Top
 Profile
 Post subject: Re: rear tyre
PostPosted: Fri Mar 14, 2014 10:34 am
Offline
Yes. Most of these rear tires will last 7000 miles. However, if you are heavy on the throttle they could wear out a lot sooner. There is a wear mark on the tires. You should change the tire when that mark is level with the remaining tread. If you can no longer see the wear mark, you are well past time to change it. Try a Michelin City Grip for your next tire. They wear longer and really hold the road.
_________________
Two Red 2013 Honda PCX150s
Givi tall windshield and tailbox on both
Lots and lots of extra lights
Custom seats from Thailand
Bad boy Airhorn on each
Takegawa Lowering Shocks on both
Top
 Profile
PostPosted: Fri Mar 14, 2014 10:41 am
Offline
Probably am a little heavy on the throttle, expressways and country lanes to and from work, WAP!
Bill smiths here I come, stung again.
Cheers Glyn
Top
 Profile
PostPosted: Fri Mar 14, 2014 10:50 am
Offline
Just booked in £75 ouch!
Top
 Profile
PostPosted: Sat Mar 15, 2014 1:05 am
Offline
Year: 2010 PCX125
Did you get the Michelin City Grips? I have them and really like the way the bike handles with them.
_________________
2010 Honda PCX 125 in Thailand (White) - "White Lightning"
2009 Yamaha Majesty YP400 in USA (Metalic Titanium) - "The Throne"
Top
 Profile
PostPosted: Sat Mar 15, 2014 3:28 am
Offline
Yes that's what they recommended :)
Top
 Profile
PostPosted: Mon Mar 17, 2014 12:13 pm
Offline
I have to disagree with mel on the mileage. My stock IRC rear tire was bald at 3000 miles. I would consider my riding style normal or average. Changing the way you brake makes a big difference on the tires. I tended to favor the rear brake until i realized how bad it was wearing. Now that i favor the front brake the rear tire wears much less. Basically what i'm saying is your braking technique will effect tire wear much more than riding style.
_________________
Top
 Profile
PostPosted: Mon Mar 17, 2014 12:33 pm
Offline
Are stock IRC tires the same quality on all PCX scooters? We changed ours at 7,000 miles and the wear indicator still showed another 500 miles were left before we needed to change it. I have also read of others on this forum getting 6,000 miles on their rear tire, so I thought that we were normal.
_________________
Top
 Profile
PostPosted: Mon Mar 17, 2014 1:17 pm
Offline
Year: SV650AL7
Color: The correct one
Braking technique is a part of riding style.
You should aim not to use your brakes, read the road and control speed with the throttle.
Using the brakes just wastes fuel and wears out your tyres and brakes
_________________
Top
 Profile
PostPosted: Mon Mar 17, 2014 1:26 pm
Offline
Don't use your brakes? Really? Riding around slow enough as to not have to use ur brakes is absolutely ridiculous. Tires and break pads are cheap.
Top
 Profile
PostPosted: Mon Mar 17, 2014 1:34 pm
Offline
Yup. I'm at 10,000 miles before I stored the PCX for winter. Still have the original rear tire, I believe I can get another 2000 miles. And during this time, watching prices on the city grips. I'll have to change out both front and rear. I do not use the rear brake unless I need more braking than the front can provide.
I do not advocate this kind of riding style, but I do it so I don't have to change the rear drum brake, and get the most even wear on the tires.
Once a week I check all my rides tire pressure. And fill the PCX to the recommend F29/R36 PSI
Top
 Profile
PostPosted: Mon Mar 17, 2014 1:50 pm
Offline
Color: White.
I was told on the CBT that you should slow down using your brakes as I warning to the road users behind you that your slowing down. .
_________________
Top
 Profile
PostPosted: Mon Mar 17, 2014 2:14 pm
Offline
Year: SV650AL7
I didn't say that you shouldn't use them at all.
Read what I wrote again.
Have another go at trying to work it out.
_________________
Top
 Profile
PostPosted: Mon Mar 17, 2014 2:22 pm
Offline
Year: SV650AL7
Indeed, also some people advocate giving the brake light a couple of flashes.
If you roll off the throttle gently and decelerate gradually people behind are much less likely to be caught out than if you brake hard.
_________________
Top
 Profile
PostPosted: Mon Mar 17, 2014 2:29 pm
Offline
I agree. And you are probably going faster by reading the road. Non of this stop and zoom off again nonsense. Keep to high average speeds.
_________________
I'm actually a nice guy and can behave :)
Top
 Profile
Who is online
Users browsing this forum: Google [Bot] and 5 guests
Search for:
Jump to:
