12v Power Outlet Question
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
I need to power at least my smartphone and preferably both my smartphone and camera as I ride. Right now I tape the compartment door shut with a piece of masking tape which works fine but looks a but tacky. Is there a better way?
Re: 12v Power Outlet Question
SECoda wrote:I need to power at least my smartphone and preferably both my smartphone and camera as I ride. Right now I tape the compartment door shut with a piece of masking tape which works fine but looks a but tacky. Is there a better way?
Get a mullet, they look very tacky.
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
I expected an answer like that but never from you. :o
Yes.
Place the camera, smartfone and USB cables inside the compartment then close it normally.
NeilForza
Year: 2014 Forza
Color: Silver
Post by NeilForza »
My socket has stopped working, I can't find a blown fuse though.
Mine is a UK model, where is the fuse?
I'll try. I don't own a Forza (pcx here), but I'm thinking you open your seat, open your battery box and lastly open the fuse bin cover. Do you have your owner's manual?
Atis
Post by Atis »
It's under the top cover of the dash above the right side box. Open the box to find a couple of screws remove them and pull up the cover. Sorry I don'the remember the fuse location or value.
Honda 2014 Forza 300 (ABS)
Honda 1995 Elite 80 (Sold)
JohnL
Ozzie Old Fart
Ozzie Old Fart
Color: Dark Red
Post by JohnL »
The fuses are inside the battery compartment, on top of the battery, in the fuse compartment.
BRed
Year: 2023 XMax 300
Color: Grey and black
Post by BRed »
there are 2 fuse boxes.....
all the heavy stuff for the engine and FI is in the lower fuse box near the battery
all the lights, horn, gauges, accessories, etc..... are under the cover of the right box
if you have ABS there are THREE fuse boxes (well, 2 and a half?)
Connect Battery Tender permanent connections to your battery. Then buy the power outlet that plugs into it, run a wire under the seat (I ran mine through the opening between the hinge), and connect your devices to it. If what you want to connect can not fit in the glove box, this is your next best option.
