Tuning the Forza 300 CVT
Maintenance, guides, and walkthroughs for your Forza. Please do not post questions about repairing or fixing your bike here.
sendler2112
Year: 2013 PCX150
Re: Tuning the Forza 300 CVT
Post by sendler2112 »
waspmike wrote:
My exhaust post was based on a scooter with after market variator with and without exhaust. It is much better with and gets about 5hp more. This is of course because the aftermarket allows the engine to rev more. Sure you can play with weights but as you say as soon as that starts then the counter spring is wrong or...or... .
If it makes 5hp more (doubtful. the most I ever see an exhaust improving is 10%) it is because of the exhaust and a higher pulling rpm which you can always get by changing weights.. Not the Variator.
The spring is a tuning non issue on these big four stroke bikes. Changing springs and clutches became popular, and necessary, on two stroke scooters with engine mods resulting in 50% horsepower increases to eliminate slipping.
robertinino
Post by robertinino »
I have clear idea.
What I want is a better acceleration expecially between range 60-100 km, and a top speed of 140 km similar to the original forza's speed.
When I started going to the forum I spoke with Be red about this problem, he suggested combo mix, but Mario experimented that is not a good solution.
Now I have to decide between: Dr Pulley 17 or 18 grams sliders and a new variator: Malossi or Autisia. I know Malossi but I don't know Autisia also if I'm attracted.
The first solution is less expensive but I don't know if is similar in satisfaction like change variator. I don't want waste money and I don't want loose the honda realiability.
Help me with your experience please
thank you very much
Robert
Mario
Post by Mario »
With the Dr.P sliders you gain reliability; )
May the Forza be with you!!
robertinino
Hi mario did you try the new clutch ?
Mario
Post by Mario »
robertinino wrote:Hi mario did you try the new clutch ?
I get it in one or two weeks.
robertinino
I send a big CIAO... to BRed where are you?
robert
robertinino
Hi Mario did you enjoy your forza? Did you travel a lot?
ciao
R
Mario
Post by Mario »
robertinino wrote:Hi Mario did you enjoy your forza? Did you travel a lot?
ciao
R
At the moment a few day's rainy weather :(
But the sunny day's are coming so I can start again to take the Forza for a fun ride every day with a big smile on my face :D
Almost got the first 1000km on it so I must make a appointment with the dealer for his first maintenance, bringing my own ( Castrol Power RS 4T 10W30 ) oil plus oil filter and a new drain bolt with magnet, can do it all by myself but need the stamp for the guarantee.
Also ordered an DNA air filter, more air and lives a live time with regular cleaning/oiling
DNA
Honda
robertinino
Mario everytime you amaze me with interesting news. Where did you by the filter? I want it me too. Could you please post the link.Now I ordered the dr pulley sliders like you, I m waiting to receive them. About oil I suggest you Barthal oil I always use it, in many comparative test result much better than castrol.
Futere step will be a new variator: malossi, but I don't know if it work well with dr Pulley sliders, or autisia variator or a new clutch (which one will be the best I m waiting your test)
thank you
ciao +
Robert
Branyers14
Year: 2014 Forza
Post by Branyers14 »
I have a Malossi variator, 16.5g, have gained acceleration, lost top speed. I too would like to know if 18g sliders would be the way to go.
robertinino
Usually here in Italy when you purchase a malossi variator it comes with two different types of rollers weights. The malossi has running surfaces that do not fit perfectly with dr pulley sliders, someone says that it's better the combination dr pulley sliders + original variator, other says that fit malossi variator is much better then dr pulley+original variator.
The 3 solution malossi+dr Pulley sliders is experimented here in italy in different scooters forum, but not for forza.
R
robertinino
mario
is it the drain bolt with magnet necessary?
Mario
Post by Mario »
Ordered the airfilter from Amazon.de
http://www.amazon.de/Honda-300-07-12-DN ... 300+filter
Drain bolt with the magnet is just an extra to collect metal particles out of the oil, not necessary but ............
Robert, what weight sliders dit you buy?
Branyers14
Year: 2014 Forza
robertinino wrote:Usually here in Italy when you purchase a malossi variator it comes with two different types of rollers weights. The malossi has running surfaces that do not fit perfectly with dr pulley sliders, someone says that it's better the combination dr pulley sliders + original variator, other says that fit malossi variator is much better then dr pulley+original variator.
R
My Malossi variator came with 6 12g rollers. For the hell of it, I put them all in. Bike accelerates very well, top speed is still around 85mph. Was hoping for more top speed, maybe once I get my Moriwaki exhaust and K&N filter installed.
sendler2112
Year: 2013 PCX150
Can you post a video so we can see the rpm versus speed?
Branyers14
Year: 2014 Forza
sendler2112 wrote:Can you post a video so we can see the rpm versus speed?
I don't have a GoPro, but I will make a mental note of it. It sits around 7500rpm at 70-75mph.
sendler2112
Year: 2013 PCX150
What is the pulling rpm during an accel run?
Branyers14
Year: 2014 Forza
sendler2112 wrote:What is the pulling rpm during an accel run?
About to go on a ride, I will report my findings.
robertinino
mario
17 grams sliders I hope will be good....
R
robertinino
branyers
why don't you try dr pulley sliders with malossi?
R
