Dasshreddar's PCX/Ruckus Hybrid
- Joemag22
Re: Dasshreddar's PCX/Ruckus Hybrid
Good work, when you sprayed the plastics did you rattle can it or use a legit sprayer? I was thinking about throwing on some plasti-dip in a couple areas but unsure if it would stick...
Current: 2011 Honda PCX125 (j.costa vario and j.costa exhaust)
Past: 2008 Honda Met (Dayton drag vario, CDI box, spark plug, kn filter, and a cup holder)
** NOR-CAL / East Bay Met Set SC **
- dasshreddar
- Year: forzaruckuspcx
Thanks Joe,
Wet sand 400 grit and spray paint
- dasshreddar
I wasn't planning on doing this mod, but when I found a 2015 headlight for only $1.99 , I couldn't resist...
- 14newlight.jpg (523.12 KiB) Viewed 1941 times
Look what you did! Fits right in. Seen that headlight somewhere before
So Really? A buck ninety nine? How did that happen?
Shazam! Score!
Shazam! Score!
- dasshreddar
It's not a direct fit, but either is a Ruckus seat
Yeah got it at cheapcycleparts.com, typo I guess, but now its $203.89 for the same light
- Year: 2015 VStrom 650
Woooooooah! Nice grab!dasshreddar wrote: Yeah got it at cheapcycleparts.com, typo I guess, but now its $203.89 for the same light
Nice of them to still process the order with the typo
Josh, doesn't his hybrid look frigin' cool? Like as in "toto awesome-ness?" I love it! And those L E Deez!
(Psst....Josh, if you thought his bike was part white,...it's Not. It's really light gray. He says, he would never go white. Ha! Story has it that local markets were fresh outta white. So, Das really settled. No need to make him feel bad about it, and I choose Not to rub it in, so I just keep re-saying,
"How Cool Is That!!" (Get my drift? Praise the Mantis!)
Das Rocks!!!
Das Rocks!!!
- dasshreddar
The 3 panels I got with the headlight are WHITE ..., but will they stay white?
"Let it Be"
- relic
- Color: red white
would like to link up with Dasshreddar and pick his brain on some his mods
- dasshreddar
Sure, what seems to be on your mind...relic wrote:would like to link up with Dasshreddar and pick his brain on some his mods
you can also PM me , but you need at least 15 posts.
- relic
- Color: red white
First of all I like what you have accomplished
The seat bracket-I see all kinds of after market stuff- moly tubing -OK to weld?
did you use the lowering one?
and what seat height did you achieve?
- dasshreddar
Thanks,
I used a stock ruckus seat frame, a lowering one or just tubing would also work, because I only used about half of the seat frame.
Seat height is currently at 28.5 inches(lowest point of the "saddle" with taller tires/stock suspension).
I also carved out some of the plastic seat pan to sit lower/trimmed the rear of the seat edge(the seat does not open and close like a stock ruckus, it is fixed).
If you wanted the seat more forward you could easily go even lower without making major frame(pcx) mods.
I first took the measurements I liked from my gy6/ruckus and went from there...
- relic
- Color: red white
Thank you
In a couple months your northern neighbour will be feeling the chill
good time to bring the bike inside and tinker
I think it need some knobby tyres
- pcxpower
Wow!!! I'm subscribing to this thread, as this build is amazing! I would not be able to do it, but I enjoy seeing what others are capable of doing to their machines
BTW: $1.99 for a PCX LED headlight is "the bargain of the century"!!!
2015 Honda PCX 125
- dasshreddar
Here is a profile pic with the 15 headlight. (change is near )
- 14l15.jpg (452.16 KiB) Viewed 1751 times
- dasshreddar
Well the 15 headlight's high beam went out the other day... (probably needed the led control unit...)
So anyway out with the New and in with the Old... Ruckus Eyes
- 14ru.jpg (568.23 KiB) Viewed 1752 times
you have to spin that around so we can see what the hell!
- pcxpower
Wow! Lots of transformations are taking place in this motorbike in the last days... You are really busy!!!!
We will need some pictures from the side of the motorbike, so that we can see the new headlight in its entirety
BTW: Thank goodness that the 2015 headlight cost you only $1.99!!! Now you can sell it and the panels on eBay, and even with the buyer aware that the high beam is MIA you can earn some bucks!
2015 Honda PCX 125
