2015 fender eliminator
Re: 2015 fender eliminator
Well Mr. WarFab... I have looked at the tuxedo tail on my 2015 PCX long enough. The unattractive extended billboard designed for European license plates has no place in American application... I don't like it anymore than you do.
Today I will take up my tail and get by. Your 'how to completely eliminate the 2015 PCX tail' publication is still coming I hope but for now this will have to do.
Any how wish me luck and have fun with your Ruckus assembly.
- tidy tail.jpeg (107.55 KiB) Viewed 3830 times
This worked out nicely... special thanks to dem0nk1d for the guts to just go for it!
No thanks to WARFAB who is slower than Moses
Tools needed;
10mm socket, hack saw, 1/4" drill bit, razor or knife, propane torch (optional)
Tools needed;
- p1.jpeg (203.7 KiB) Viewed 3823 times
- p2.jpeg (142.1 KiB) Viewed 3823 times
- p3.jpeg (118.05 KiB) Viewed 3823 times
- p4.jpeg (106.98 KiB) Viewed 3823 times
- p5.jpeg (139.89 KiB) Viewed 3823 times
- p6.jpeg (130.24 KiB) Viewed 3823 times
- p7.jpeg (118.21 KiB) Viewed 3823 times
The propane torch if used carefully will give a finished look to the rough cut edge after you clean it up with a razor and sand paper. Practice on the scrap piece using a parallel angle to the flame never letting it actually get hot and you will see what I mean
You should set aside a couple hours for the whole process... ENJOY!
- p8.jpeg (155.31 KiB) Viewed 3824 times
- ScooterMan
Nice work guys. I just got a 2015. I'll be poking my head around and seeing what I can do with the rear fender. =) Liking both ideas so far.
2015 PCX 150 (White)[/color]
The only reason I did not go further into the removal was because WARFAB never showed us how. Now that I have done it my way and kept half the tail and reflectors I'm totally satisfied with the look and function. I will not do anymore to tidy up the tail on a 2015.
- ScooterMan
My fender chop...very similar to the one above, tucking the plate right up next to the reflector and used wood screws with a dab of goo on the back of the screw to keep if from backing out should it ever try to. Did not run the side reflectors like the post above. 11.1oz removed (almost 3/4 lb).
First pic you can see where I drilled the holes on both sides just below the reflector for the license plate.
Yep that's a nice clean job Scooterman... its the way it should be, brings balance and symmetry to the tail end of 2015 PCX.
Now what happened to your Honda logos? Are we ashamed of our maker? Everybody knows its not a Harley
- ScooterMan
Prev owner removed them. The "Honda" sticker above the license plate is $1.30...will prob order that next time I get a belt and stick it on there. Would cost me $60 to replace the "PCX 150" badges on the side though...will prob leave that the way it is.
That's goofy... did he offer to look around for the badges? I assume he didn't know where they were at the time of sale.ScooterMan wrote:Prev owner removed them. The "Honda" sticker above the license plate is $1.30...will prob order that next time I get a belt and stick it on there. Would cost me $60 to replace the "PCX 150" badges on the side though...will prob leave that the way it is.
- ScooterMan
He said they broke when he took them off. I'm on the fence about them really. I guess they can stay off. But, at the same time, with so many cheap Chinese scooters out there, might be nice to rub it in to others that I drive a superior Honda!
I want to see the one on the wind screen now
The bike looks GREAT! Sweet deal for sure.
- Year: 2015 VStrom 650
Nice job tidying up the rear end, guys!
You can feel good about this mod, drilling out the extra holes for the side refactors is optional but I want all the visibility I can get at night.
I took my reflectors off, but they'll go back on when the time changes next month. Right now, I only ride in the daytime and it looks cleaner without the reflectors. But, because of "wonderful" daylight savings time, it'll start getting dark before I get off work so the reflectors will have to go back on. I'd like to add some additional lighting, but I'm not sure how much longer I'll be keeping the PCX. I hope to get a good combo deal this winter with a Forza + NC700X.
Gonna weld a few up right now
[attachment=-1]uploadfromtaptalk1412475213946.jpg[/attachment]
- uploadfromtaptalk1412475213946.jpg (151.16 KiB) Viewed 3760 times
And hell ya nice job with the diy fender mods
Having some fun with these welds
[attachment=-1]uploadfromtaptalk1412476491828.jpg[/attachment]
- uploadfromtaptalk1412476491828.jpg (109.79 KiB) Viewed 3759 times
HEY! WARFAB took a day off work, last post September 22nd Nice weld, I know how hard it is to run a bead like that on aluminum without a tig welder (tunston inert gas) you make it look professional.
Don't build us anything that rattles under any RPM please. There is a rash of mysterious noises, buzzing, rattling and vibrations making members crazy lately. Dealers saying they don't hear them or it's normal sounds on a scooter So far nothing out of the unusual coming from mine.
lol my profession is welding [WINKING FACE]
Yeah mine has a noise too I think it's coming from the valve train I need to check my valve lash
You kind of need a tig to weld aluminum like this
How did you separated the "mud flap" from the license plate light?WORFAB wrote:Ok here you go pictures of my fender eliminator reuses factory mounts hardware and light, no cutting no destroying and you can go back to stock whenever.
[attachment=-1]uploadfromtaptalk1409404348875.jpg[/attachment][attachment=-1]uploadfromtaptalk1409404364249.jpg[/attachment][attachment=-1]uploadfromtaptalk1409404383464.jpg[/attachment]
I checked on mine and i haven't saw any screw holding it...
Can you help me?
Thanks
