Dead battery
lolofigo
Year: 2012
Color: Silver
Dead battery
Post by lolofigo »
Today's morning my battery died on pcx. As I have my car in the garage for MOT I have had to buy new battery from the shop not from eBay or some place on interweb to get bike ready for tomorrow. Was quoted eye watering £80 for yuasa but bought li ion instead for £69. Weights 0.6 kg instead of 2.1kg like stock one. That's gonna be boost in performance due to weight saving :).ImageImage
Battery is smaller than stock and comes with family spacers.
lolofigo
Year: 2012
Color: Silver
Re: Dead battery
Post by lolofigo »
lolofigo wrote:Today's morning my battery died on pcx. As I have my car in the garage for MOT I have to buy new battery from the shop not from eBay or some place on interweb. Was quoted £80 for yuasa but bought li ion instead for £69. Weights 0.6 kg instead of 2.1kg like stock one. That's gonna be boost in performance due to weight saving :).ImageImage
Foam spacers. Stupid thing.
Re: Dead battery
Great information!
Re: Dead battery
1.5kg must be worth another 20mph.
Re: Dead battery
Interesting! Let us know how it performs. I thought about getting one of those but when I looked them up the price was higher than the normal replacement battery. I am curious as to how well they perform and how long they last.
easyrider
Color: blk
Re: Dead battery
Post by easyrider »
The problem with Lithium, there is usually no warning or slowing down. When they go dead they drop dead. Not sure how they are to jump start. Maybe some others will chime in that have one..
JohnL
Ozzie Old Fart
Ozzie Old Fart
Color: Dark Red
Re: Dead battery
Post by JohnL »
I've been running a lithium battery since November 2014 with absolutely no problems, it first starts every time. When I'm not using the scoot for a few days I put it on the charger. The original Yuasa stays on trickle as a backup, but I've never had to use it. The light weight and smaller size make it really easy to remove if necessary. The only negative is the purchase price. If you have the cash it's a good investment.
Re: Dead battery
easyrider wrote:The problem with Lithium, there is usually no warning or slowing down. When they go dead they drop dead. Not sure how they are to jump start. Maybe some others will chime in that have one..
L-ions don't like humidity, condensation or any kind of moisture. I'm sure it's sealed but it must have breather ports on it somewhere to combat condensation, don't get water in those ports.
Re: Dead battery
I want a di-lithium one :D
easyrider
Color: blk
Re: Dead battery
Post by easyrider »
I don't think you can use a regular (lead acid ) trickle charger on a lithium ion battery.I don't think the smart function works on them and you run the risk of cooking it. Not sure how it works however????
JohnL
Ozzie Old Fart
Ozzie Old Fart
Color: Dark Red
Re: Dead battery
Post by JohnL »
I use the Techmate Optimate 2 charger. Recommended for most types of 12v batteries
https://www.revzilla.com › Street Gear › Accessories › Battery Chargers
I make a point of not submerging the battery in water. If that happens, I'm in way beyond my depth. :D :D :D
We do have a high humidity environment in Queensland in summer, but it doesn't appear to have any detrimental effects on my battery.
easyrider
Color: blk
Re: Dead battery
Post by easyrider »
JohnL wrote:I use the Techmate Optimate 2 charger. Recommended for most types of 12v batteries
Hey there John.. you should be advised that the battery charger you are using is not really suitable for your battery and I would caution using it because it may ruin it over time. You should check with their website as what they recommend for Lithium is a different model.. FYI take a look.. Hope this info helps .
https://tecmate.com/products/optimatelith0-8/
https://tecmate.com/wp-content/uploads/ ... 151022.pdf
JohnL
Ozzie Old Fart
Ozzie Old Fart
Color: Dark Red
Re: Dead battery
Post by JohnL »
Thanks for the advice easy. I believe there are different types of lithium battery and the Techmate was specifically recommended by the battery supplier. As it's coming up three years since I bought the battery and charger, I'll probably take my chances. This is mostly influenced by financial considerations and also my desire to live life on the edge :lol: :lol: :lol:
I do appreciate your advice.
