CVT mods for PCX 150?
sendler2112
Year: 2013 PCX150
Re: CVT mods for PCX 150?
Post by sendler2112 »
Dr.Pulley 20x15 12gm sliders:
In the USA...
http://www.partsforscooters.com/169-259 ... ts?whence=
From Taiwan...
http://www.ebay.com/itm/DR-PULLEY-ROLLE ... 12&vxp=mtr
dasshreddar
Year: forzaruckuspcx
Post by dasshreddar »
dasshreddar wrote: Well I went with the 20x15 12g Dr.P sliders
:ugeek: here are my first test results w/ feelings :lol:
top speed gain of 3mph 8)
steep ass uphill speed gain of 5mph :D
improved mid-range(what I wanted) :D
"shiftiness" :|
belt wear? :|
mpg? :|
Here are the new "correctly installed" results. :lol:
top speed gain of 2mph, hey I lost 1mph :x
"shiftiness"/ belt slip, not so anymore, smoother, but a little more shudder at takeoff :|
belt wear/mpg probably nothing to worry about 8)
p.s. not sure why I was able to get 73mph rev limit on the stand, and only 69mph rev limit on the road...
also I got my sliders at extremescooters.biz super fast and easy
dasshreddar wrote:p.s. not sure why I was able to get 73mph rev limit on the stand, and only 69mph rev limit on the road...
Likely because the bike doesn't have the power to push it to 73 when it's up against all the air resistance at that speed. Air resistance is the main source of drag at speed, reducing it will make you go faster. If you tuck in, you might get closer to 73.
Pcxdemon
Post by Pcxdemon »
"shiftiness" :|
belt wear? :|
mpg? :|
Sliders are marginally taller than rollers when placed in the vario, so in turn that diff will bring your pulleys bit closer together in stationary position which will force the belt to sit slightly higher between the pulleys on takeoff,so my advice is to get a small washer to offset that diff and id say .3mm washer would do the job. Shudder would be eliminated without any adverse affects elsewhere..
Also mpg and belt wear will be unaffected by running sliders in there and on the plus side sliders will outlive rollers by a long shot,so less top speed drop off over longer periods of time and more consistent transmition operation.
sendler2112 wrote:Dr.Pulley 20x15 12gm sliders:
In the USA...
From Taiwan...
Got em. Cheers
dasshreddar
"shiftiness" :|
belt wear? :|
mpg? :|
Well I got the Yuminashi speed booster variator v.2013 and gates reinforced belt installed and tested. ;)
It definitely raises the top speed possible(downhill :lol: )
is it that much better than just stock variator with 12g sliders, not a lot, but it is better(for me).
I did not notice the shudder at take off(must be rollers vs. sliders)
It felt like midrange acceleration was improved on the flats, but the hills felt the same :) :| .
I got it up to 80mph on the stand before rev limit...:)
70mph(74gps) on the road, but it still had more...( ran out of road) 75mph should not be a problem 8)
Mgalutia88
Year: 2013 PCX 150
Post by Mgalutia88 »
Dasshredder, a givi short screen makes you much more aerodynamic and helps top speed a lot!
dasshreddar
Mgalutia88 wrote:Dasshredder, a givi short screen makes you much more aerodynamic and helps top speed a lot!
Yes, but looks so hideous :lol:
Mgalutia88
Year: 2013 PCX 150
I know but it's not as ugly as a tall screen! Lol.
MCJohnny
Year: 2013 150cc
Post by MCJohnny »
hi all.
just ordered dr pulley 12gs where can i get shims or spacers to prevent a shudder
dasshreddar
Hi, not really sure where to get them... hardware store maybe?
Even my Yumi vario and 12g rollers are making a bit of shudder at take off.
Sendler has been using the 12g sliders for a long time without spacers/washers. really not much to worry about. just vibrates a bit.
wingz
Color: Dark Silver
Post by wingz »
Mine didn't shudder but I added a 0.5mm spacer to increase rpm.
You can use a washer.
MCJohnny
Year: 2013 150cc
Post by MCJohnny »
okay thanks.
where did you get your yuminashi i have been thinking about the 175 light bore kit with the valve springs racing set but cant seem to find a site that sells to the usa
i also want to try the inertia power booster set seems all the reviews are mixed on it so i think i will just try it and see
dasshreddar
I got my yuminashi vario from pcxracing in france.
I've been wanting a big bore for a long time, but info for the 150 is really sketchy...(not usa).
MCJohnny
Year: 2013 150cc
Post by MCJohnny »
Ya I was talking to Honda there should be a bore up kit from them soon. But they did say they could fine one. And if they put it in they will honor the warranty. I would just do it my self but that is cool of them.
Scooter dynasty said next year they will have a bore up kit for the 150.
I am 6 4 and 230 pounds so the PCx needs a little help with me on it my wife gets it to 70 with no
Problem where I barely get to 60 on it.
We will see how good the sliders do that may be all it needs.
mikelx5
Post by mikelx5 »
If u try he inetia booster make sure the fan doesnt contact the radiator doesnt contact the
DISOBEDIENCE CREW
Pcxdemon
Post by Pcxdemon »
mikelx5 wrote:If u try he inetia booster make sure the fan doesnt contact the radiator doesnt contact the
Thats what im like after few drinks too.... :lol:
GeeGusKahn
Post by GeeGusKahn »
wingz wrote:Mine didn't shudder but I added a 0.5mm spacer to increase rpm.
Hay wingz, what is the placement of the washer??
thanks
Sean
Sean, who loves Hi-Vis everything.
2013 Red PCX150 - NCY V and DF, 11 g rollers, stock OEM belt.
2006 Wht. Burgman 650, 30,000+ miles, running like a champ..
MCJohnny
Year: 2013 150cc
Post by MCJohnny »
ordered a yuminashi speed booster v.2013 variator, inertia power booster and a gates v-belt
wont be here for a bit but we will see how it goes
MCJohnny
Year: 2013 150cc
Post by MCJohnny »
dasshreddar have you tried the sliders in you yuminashi variator yet?
