Lowered
- Year: 13
- Color: red
Lowered
Has anyone lowered the pcx, the front seems easy just slide the tubes up a bit, looks like shorter shocks for the rear. Shorter side stand might be needed as well. Add a pic if you have one!
Re: Lowered
Drifter, the best bet is to just chop the foot off and reweld it. This whole buying another kickstand is too expensive... Plus you get to learn a valuable trade! if you don't have the funds, i am pretty sure the local muffler shop will do it under 10 bucks.
Now for shocks, the rear spring in the back shock is replaceable, if you want to go crazy you could either heat and compress the stock shock making it shorter, or cut out a few coils.. This is a low budget mod of course.
- Indyglow
Re: Lowered
I got lowering shocks for the rear plus got my seat cut and plastic welded to lower that, too. I did these things to make it easy for me to have both feet flat on the ground. Is this what you mean by lowering, or are you talking about something else?
- Year: 13
- Color: red
Re: Lowered
I have done the cheap fix on several motorcycles through the years, cutting springs and side stands. It works, remember lowering links that changed the angle of the shock....wont work on pcx cause the shock is at the end of the swing arm.
Indy, where did you get the shocks, do you have pics? How much did they cost and how low did you go?
Adding the bigger tires just ups the seat height, so lower it must go. Im looking at one of the seats like Mel has. This damn hump has got to go!
- Indyglow
Re: Lowered
viewtopic.php?f=3&t=2473&hilit=takegawa+lowering+shocks This link shows the shocks.
- Indyglow
Re: Lowered
You'll have to copy/paste the link, I forgot how to make links go live...............
Re: Lowered
I have the Takegawa lowering shocks on both of our bikes. It works well for lowering the seat a little over 1 inch. However, if you can afford to and really want to lower your bike a lot you could extend the rear engine mount. I haven't done this but it looks like some riders in Thailand have done it. Looks like you could go 3 inches back and lower it quite a bit. I don't know if you would change shocks or not, but here is the thread.
http://www.hondapcx.org/viewtopic.php?f ... ear+mounts
- Year: 13
- Color: red
Re: Lowered
Thats an informative thread!! I wonder if you buy the shock mounts alone you could lower that way. What did you pay for the shocks?
