Page 2 of 2
Re: Adjustable Levers?
Posted: Sat May 30, 2020 5:08 am
by iceman
I find the front brake lever for my length of fingers is not great, especially now I have wind guards fitted which means my hand/fingers are more towards the inside half of the lever. The lhs rear brake lever is curved differently front the rhs and I have no issues with that, just the front brake lever. So, adjustable ones may be a good purchase.
Posted: Sat May 30, 2020 11:23 pm
Gil wrote:Why do people install these? Do they have less play than the OEM ones?
By play do you mean up and down movement because you can shim that out on the standard levers.
Posted: Mon Jun 01, 2020 5:37 pm
by Conelite
Personally, the feel is better. The levers are shorter and adjustable and the throw/pull just seems stronger. Play is better similar to stock.
Number 1 reason, they just look better.
Posted: Wed Jun 03, 2020 12:29 am
by Gil
Conelite wrote:Gil wrote:Why do people install these? Do they have less play than the OEM ones?
OK, I might just get a set then. I tend to pull on the brake levers from the inner part of the lever.
I don't like the vertical play of the stock levers though, that's the only thing that bothers me.
Posted: Wed Jun 03, 2020 1:41 am
Gil wrote:Conelite wrote:Gil wrote:Why do people install these? Do they have less play than the OEM ones?
They generally have more play than stock as they have two pivot points rather than one.
Posted: Thu Jul 15, 2021 1:09 pm
by jbecktahoe
Does anyone have a link for the aftermarket brake alloy levers on Amazon, NOT the short ones ?
I'm looking for ones that ship
from Amazon or from the US and not from China or out of the country...
Also, to answer the "why" question, I prefer this style of levers because they are thicker than the stock ones.
Being made of thicker aluminum, there is (slightly) more leverage and more comfort when you pull, and less of a feel of the lever digging into your fingers.
Thanks!
Conelite wrote: ↑Fri May 29, 2020 4:46 pm
I bought the Amazon ones. Work great. Much better than the stock ones.
