Page 1 of 2
Idle Stop Accident
Posted: Wed Apr 03, 2013 5:32 am
by haildamage
went to the neighborhood izakaya (bar/restaurant) and the owner told me he had had an accident on his PCX. he was at the local chiropractor and was trying to push his bike and hit the throttle which engaged the engine as it was off in idle stop mode. the bike lunged forward and broke out a window pane.
he hurt his knuckles a bit but was wearing gloves and it did a little damage to the bike.
i thought you had to have weight on the seat or the engine wouldnt come on. i guess not...
Re: Idle Stop Accident
Posted: Wed Apr 03, 2013 6:11 am
by Taz
The underseat switch should stop this happening but some people disable it such as by taping it over especially if a light weight or if sitting a long way back on the seat. I sit a long way back on my humpless seat but added thick tape to ensure seat switch still activates the idle stop.
Posted: Wed Apr 03, 2013 6:28 am
I discovered a while ago that I can get off and on mine with the engine running or in idle stop.
Ever since I have always turned the key before getting off.
Posted: Wed Apr 03, 2013 8:06 am
haildamage wrote:went to the neighborhood izakaya (bar/restaurant) and the owner told me he had had an accident on his PCX. he was at the local chiropractor and was trying to push his bike and hit the throttle which engaged the engine as it was off in idle stop mode. the bike lunged forward and broke out a window pane.
Why was he pushing it with the engine running, that's kind of what the engine is for
Nothing is idiot proof.
Posted: Wed Apr 03, 2013 8:13 am
by haildamage
i too thought the seat switch should keep it from going without weight on the seat. i will try it with my bike tomorrow. his bike is bone stock and he is not the type to have modded anything.
the engine was off but in idle stop, so when he was pushing it probably to back it out he hit inadvertently twisted the throttle, the bike started and lunged forward.
Posted: Wed Apr 03, 2013 9:27 am
haildamage wrote:i too thought the seat switch should keep it from going without weight on the seat. i will try it with my bike tomorrow. his bike is bone stock and he is not the type to have modded anything.
Mine, an esp125, doesn't have a seat switch
Posted: Wed Apr 03, 2013 9:31 am
by haildamage
you you wrote:haildamage wrote:i too thought the seat switch should keep it from going without weight on the seat. i will try it with my bike tomorrow. his bike is bone stock and he is not the type to have modded anything.
your location isnt listed. do you have an idle stop bike?
Posted: Wed Apr 03, 2013 9:36 am
haildamage wrote:you you wrote:haildamage wrote:i too thought the seat switch should keep it from going without weight on the seat. i will try it with my bike tomorrow. his bike is bone stock and he is not the type to have modded anything.
England. Yes it's an idle stop bike, just no seat disconnect.
Posted: Wed Apr 03, 2013 1:23 pm
by brains_t
When I was researching the PCX last autumn, there was one on ebay where the owner had revved it in his gf's front garden and it went through their wooden fence smashing most of the panels.
Idle Stop Accident
Posted: Wed Apr 03, 2013 2:24 pm
by SmellyTofu
My seat switch doesn't always work so the idle stop didn't work for a whole until I whacked the area where the switch is. However, I'm very cautious if the engine is running not to have my hands on the throttle if I want to push it for whatever reason like getting it off the centre stand
Posted: Wed Apr 03, 2013 6:56 pm
by st3v4nt
On PCX 150 Honda remove the seat sensor, so the idle stop will still engage when you get off from PCX.
Unless you turn off the PCX engine also.
Luckily whenever I do that (i.e opening fence to enter or leave home) I always use side stand.
Since PCX Side Stand have kill engine switch it also turn off the idle stop. So always make
sure you turn off the idle stop if you plan to push PCX around without sitting on PCX.
Posted: Wed Apr 03, 2013 7:45 pm
by haildamage
i suppose your bike doesnt need the seat switch since it has ESP to know when not to start.
Posted: Thu Apr 04, 2013 3:10 am
Very good
Posted: Thu Apr 04, 2013 7:55 am
by Cracksta
maybe when he was pushing the bike the seat had something heavy enough to press the switch? otherwise the seat has sagged enough to always engage it.
the only time i need to push the bike is when i get home, i need my keys to open the garage door so the bike is off anyway.
Posted: Thu Apr 04, 2013 8:34 am
by Urbanian
I see there are no Americans responding to this thread...
Unmanned flight isn’t a problem here in the US as we don’t have idle stop. Not only that, but we have a government mandated feature that doesn’t allow you to unfasten the seat belt until the key is removed from the ignition.
Posted: Thu Apr 04, 2013 8:52 am
I didn't realise that the US model PCX had seat belts or central locking.
Must be quite some machine.
Posted: Fri Apr 05, 2013 9:26 am
by haildamage
not sure what that switch under the seat does. my bike will start with a twist of the throttle from idle stop whether or not i am sitting on the seat. you should be sure to switch to idling mode when pushing the bike if you are too lazy to turn the key to off.
Posted: Fri Apr 05, 2013 11:12 am
by jeff spahn
Urbanian wrote:I see there are no Americans responding to this thread...
Funny.
Posted: Fri Apr 05, 2013 4:23 pm
by maddiedog
gn2 wrote:I didn't realise that the US model PCX had seat belts or central locking.
First mod I did to mine was remove the beeping sensor and indicator that went off every time I forgot to put my seatbelt on. Can you believe they're talking about forcing us to retrofit airbags too?
Back on topic, couldn't that accident have been easily avoided by the key in the off position, killswitch engaged, or the idle stop off? It's unfortunate, and a good story to share so everyone with idle stop is more careful, but at the end of the day sounds to me like pure user error.
Posted: Fri Apr 05, 2013 5:43 pm
by haildamage
maddiedog wrote:gn2 wrote:I didn't realise that the US model PCX had seat belts or central locking.
user error indeed, he was the first to admit that it was a careless and stupid accident. it sounds like something i would do! there is no killswitch on idle stop models (first bike i've ever owned without one). to prevent this from happening when moving the bike around you should either:
1. turn the key off
2. switch the idle mode to 'idling' do not have it in idle stop mode
3. put the kickstand down to engage the kickstand kill switch
