That would indicate a range of over 700 affected scooters, assuming sequential numbers.robisc wrote: Here the last 3 digits of 3 VINs of affected Forza 300:
097
256
800
That's way more than I was hoping to see.
Each Forza market will probably have duplicate numbers in the range of the last 6 digits....
there is a market identifier code number in the VIN numbers that allows this, one of the two digits right after the NF04 model code.
Each country will have a different code number or letter in that field and will probably use sequential number starting with 000001...for the last six digits.
but in each market, the VIN number of any Forza with a failed fuel pump should become a good marker for the production runs using defective fuel pumps, even if "birth dates" are not known?
