Annual oil change vs. maintenance interval schedule
Posted: Sun Aug 02, 2015 9:39 am
by Hypnos
I live in Canada, so unfortunately I cannot ride all year round. On average I may not drive more than 3,000 to 4,000 Km annually.
Should I do an oil and filter change at least once a year, or should I wait until the next maintenance check is due (I think at 7,500 Km)? Is it enough that I add oil if needed in the meantime?
If I do an oil change every year, should it be at the end of the season, when I get it ready for winter, or at the beginning, at Spring time?
Thank you.
Re: Annual oil change vs. maintenance interval schedule
Posted: Sun Aug 02, 2015 9:42 am
by j.d.b.
I live in Michigan and I change oil seasonally, usually at the end of the season before storage.
Posted: Sun Aug 02, 2015 9:52 am
by SteveP
End of season would seem best...gets rid of any contaminates and coats internal engine parts with fresh oil that should reduce corrosion over the long winter months.
Posted: Sun Aug 02, 2015 11:10 am
Hypnos wrote:Should I do an oil and filter change at least once a year
Yes.
When the scooter is in long term storage, do not start it and let it idle without riding it.
Change the oil after the winter just before you start riding again.
Posted: Sun Aug 02, 2015 2:25 pm
by waybar
My service manual says change the oil at 600 miles (1,000 km) initially, and then every 8000 miles (12,800 km) OR 12 months. So if you don't put that many miles on each year, you should still change it every 12 months.
Posted: Mon Aug 03, 2015 6:32 am
gn2 wrote:Hypnos wrote:Should I do an oil and filter change at least once a year
Yes.
I've done this for the best part of 40 years without any problems
Posted: Thu Aug 06, 2015 3:46 pm
by trigg123
Definitely change annually,and remember new oil never hurt anything. And if you do it yourself. The cost is very low.
Posted: Thu Aug 06, 2015 4:01 pm
by Jge64
It's so damn cheap & easy to change, I'll override the manual and change it every 1000 miles...which for me, will be every couple months.... It's such a small capacity, oil gets dirty faster than a 4/6/8 cyl car engine, particularity since all my riding is urban stop and go.
Posted: Thu Aug 06, 2015 11:06 pm
by iceman
1000 miles seems excessive, maybe 3000 or so if you really wanted to. Synthetic oil is supposed to last 2-3 times longer than non synthetic so 5000 miles is nothing.
Posted: Fri Aug 07, 2015 1:39 am
Changing the oil at 1000 miles would be like going grocery shopping then throwing 80% of your purchases in the bin before you even get home.
Posted: Fri Aug 07, 2015 1:46 am
by relic
For the first time I'm going to agree with GN2
don't over service
Posted: Fri Aug 07, 2015 12:23 pm
by Jge64
At a quart, i dont care, 1000 miles for me....doing some recalculating, thats about 6-8 months for me so its not really too distant from the 1 yr recc in the manual.
Posted: Fri Aug 07, 2015 2:51 pm
by DAB
Another thing to consider is the engine alloy is soft and you would not be the first person to bugger the drain plug thread.
Posted: Fri Aug 07, 2015 2:56 pm
by Jge64
Nope...hoping my fumoto valve fits.....no thread problems.....
Posted: Sat Aug 08, 2015 12:01 am
Jge64 wrote:Nope...hoping my fumoto valve fits.....no thread problems.....
I thought of this but don't you think it'll be a bit exposed to damage?
Posted: Sat Aug 08, 2015 12:31 am
by Jge64
Test fit shows exhaust lower, stay tuned ....see also stahlbus valves.....
