camshaft
troy
camshaft
Post by troy »
Has anyone put in a CNC X250RR 8.6 CAMSHAFT & LARGE DIAMETER ROLLER ROCKER kit in there Honda pcx150
STOCK motor
Re: camshaft
yes but we haven't heard from the guy since... perhaps he blew up with the bike.
dasshreddar
Year: forzaruckuspcx
Re: camshaft
Post by dasshreddar »
ME (also the yumi TB and bigger injector)... slightly better than stock, but worth it :| maybe.
probably works better with a BBK... but Forza swap :lol: now thats the ticket 8)
Re: camshaft
dasshreddar wrote:ME (also the yumi TB and bigger injector)... slightly better than stock, but worth it :| maybe.
and there he is 8) step back people... we have a whisperer
BPT7594
Re: camshaft
Post by BPT7594 »
Stock motor has too low static compression ratio for such a big cam like Yuminashi's.
I put one in a Vario 150 stock (which has the same engine as the new gen PCX150 LED).
Results are not too good. Went back to stock. Yuminashi cam will benefit a bigger engine + much higher compression ratio.
troy
Re: camshaft
Post by troy »
Has anyone tried a SP TAKEGAWA sport camshaft in the PCX 150 stock motor
BPT7594
Re: camshaft
Post by BPT7594 »
troy wrote:Has anyone tried a SP TAKEGAWA sport camshaft in the PCX 150 stock motor
My personal opinion is you should not try a racing cam in a stock motor with low compression (10.6).
The valves will never touch the piston, but performance wise I don't know.
Should be a good project to try.
j.d.b.
Re: camshaft
Post by j.d.b. »
So, when replacing the cam, what else is being changed in the system along with it? Larger intake and exhaust as well as spark/fuel maps(calibration)?
BPT7594
Re: camshaft
Post by BPT7594 »
j.d.b. wrote:So, when replacing the cam, what else is being changed in the system along with it? Larger intake and exhaust as well as spark/fuel maps(calibration)?
Depends on how deep your pocket is and subsequently your overall setup.
Larger intake and exhaust should only be done when fitting a bigger piston.
Re-tuning the fuel map with a good fuel controller piggyback will be absolutely necessary.
