Page 1 of 2
Clutch chatter
Posted: Thu Dec 15, 2016 1:27 pm
by easyrider
Glazing of the pads and bell seem to be all too common on this scooter.I find myself roughening pads and bell about every 2k miles.It makes a huge difference in smooth acceleration and deceleration.At the same time a greasing of all the inner and outer bearings are done routinely.Any better after market clutches than KWH( Honda)?
Re: Clutch chatter
Posted: Thu Dec 15, 2016 2:35 pm
by fish
I find that the clutch chatter disappears if I stop babying the throttle when I pull away.
Launch it with a solid throttle to lock up the clutch soonest, reduces clutch slipping which equals glazed pads.
Works on the Forza, Burgman and the Kymco.
Re: Clutch chatter
Posted: Thu Dec 15, 2016 4:03 pm
by easyrider
Yes, that does work well you are right, I just am always not in a position to nail it. I was wondering if any other after mkt clutch has better performance in this regard.
Re: Clutch chatter
Posted: Thu Dec 15, 2016 6:25 pm
by chicaboo
Lots of aftermarket clutches on
http://japan.webike.net/ 125cc and 150cc are the same.
I've got a cheap KN Planning performance clutch sitting in a box for when it's needed.
Re: Clutch chatter
Posted: Fri Dec 16, 2016 11:15 pm
by BPT7594
I use, and sell, the stock 110 Honda scooter clutch pads to PCX engines all the time. It eliminates the clutch chatter issue almost 100%
Re: Clutch chatter
Posted: Sat Dec 17, 2016 8:45 am
by easyrider
Where do you get those pads? Appreciate more info thx.
Re: Clutch chatter
Posted: Mon Dec 19, 2016 2:43 am
by BPT7594
easyrider wrote:Where do you get those pads? Appreciate more info thx.
I buy it normally from local Honda dealers. A clutch pad like that costs about 20$.
Re: Clutch chatter
Posted: Mon Dec 19, 2016 4:21 am
by iceman
BPT7594 wrote:easyrider wrote:Where do you get those pads? Appreciate more info thx.
So over time it performs better than the stock one - less prone to develop glazing?
Re: Clutch chatter
Posted: Mon Dec 19, 2016 9:16 am
by BPT7594
Next to "never". The problem is the weight of the clutch pads of the pcx. The material is also a cause.
I have had them on for over 10000 miles and no chatter even at very low speed.
Re: Clutch chatter
Posted: Mon Dec 19, 2016 10:33 am
by easyrider
Is there a part number to go by ??
Re: Clutch chatter
Posted: Mon Dec 19, 2016 8:19 pm
by BPT7594
easyrider wrote:Is there a part number to go by ??
22535-KVB-900.
Don't buy from Thai site, they will cost you a lot.
Re: Clutch chatter
Posted: Mon Dec 19, 2016 9:20 pm
by iceman
Re: Clutch chatter
Posted: Tue Dec 20, 2016 7:48 am
by easyrider
I think I will order them straightaway.. However I noticed that the part number for the PCX is 22535-K35-Voo and the revised (110) is 2235-KVB -900. I was just wondering will there be any modification requirements since the part numbers differ. Will the springs need any attention or will there be any fitment issues to contend with..Thx
Re: Clutch chatter
Posted: Wed Dec 21, 2016 6:54 am
by BPT7594
easyrider wrote:I think I will order them straightaway.. However I noticed that the part number for the PCX is 22535-K35-Voo and the revised (110) is 2235-KVB -900. I was just wondering will there be any modification requirements since the part numbers differ. Will the springs need any attention or will there be any fitment issues to contend with..Thx
It fits like normal. No need to modify anything.
Re: Clutch chatter
Posted: Sat Jan 07, 2017 1:46 pm
by easyrider
BPT7594 wrote:easyrider wrote:I think I will order them straightaway.. However I noticed that the part number for the PCX is 22535-K35-Voo and the revised (110) is 2235-KVB -900. I was just wondering will there be any modification requirements since the part numbers differ. Will the springs need any attention or will there be any fitment issues to contend with..Thx
You are 100 % correct.Appreciate the great tip . Installed and works perfectly FYI link below
https://1drv.ms/v/s!AvV-j2ZMUDvrnRSXsFyPPASrLYNM
Re: Clutch chatter
Posted: Mon Jan 16, 2017 10:06 am
by fast1075
I am at 10K miles. Clutch chatter is at times maddening. I bought new KVB pads, and a new driven pulley and belt. I am going to install them soon.
Re: Clutch chatter
Posted: Mon May 11, 2020 2:55 am
by op3l
Necroing an old thread cause the clutch drives me nuts sometimes on my 2018(or 2019 in the US) PCX 150.
Would the 22535-KVB-900 clutch work for my PCX or is that for the 125 version only?
Re: Clutch chatter
Posted: Mon May 11, 2020 3:11 am
by alx123
They're now selling carbon type aftermarket clutch pads that solved the problem. Used mine 30,000 kms without any problems.
I think you can find them in Vietnam as well
Re: Clutch chatter
Posted: Mon May 11, 2020 3:18 am
by iceman
I bought the generic clutch pads mentioned above long ago as clutch chatter was bad for me - however, over a year on I am still on the orginals as I found cleaning the powerdery crud out of the housing and not being too gentle has eliminated the issue entirely, so still on the original pads as stated and 20,000 miles on they still look in good condition and work great.
I've never gone full throttle, just give it a bit of gas to start rather than slowly turning the throttle from start-off like I did when new.
Re: Clutch chatter
Posted: Mon May 11, 2020 3:45 am
by op3l
alx123 wrote:They're now selling carbon type aftermarket clutch pads that solved the problem. Used mine 30,000 kms without any problems.
I'll give those a search, but as I'm not too familiar with the local language here it's easier for me to just get the original honda part. Thus why I'm trying to find if the 22535-KVB-900 clutch will work for PCX 150 as well.
iceman wrote:I bought the generic clutch pads mentioned above long ago as clutch chatter was bad for me - however, over a year on I am still on the orginals as I found cleaning the powerdery crud out of the housing and not being too gentle has eliminated the issue entirely, so still on the original pads as stated and 20,000 miles on they still look in good condition and work great.
Now that you mention it, it seems to only happen when I go on rides with my wife. She prefers slower speeds so I usually start off gently and usually by the 4th light the bike will shudder like crazy pulling away from a stop. I've been throttling the bike with both brakes held firm and letting it grind away some of the clutch material and that'll smooth it out for a bit.
When I ride by myself though I accelerate pretty hard and yea, not much issue there. Only going over the odd speed bumps does it shudder again.
I would still like to switch the part but I'm not too technical savvy. Could I just go to the honda dealer, ask for the part number and install it or are there any changes that need to be made?
