Tuning the Forza 300 CVT
robertinino
Re: Tuning the Forza 300 CVT
Mario
in what you gain with Dna airfilter, acceleration , top speed ?
Branyers14
- Year: 2014 Forza
I am, I have some 18g sliders on order. Honestly though, I am satisfied with the 12g rollers. Acceleration is very brisk.robertinino wrote:branyers
why don't you try dr pulley sliders with malossi?
R
Why not stick to the12g rollers then?Branyers14 wrote:I am, I have some 18g sliders on order. Honestly though, I am satisfied with the 12g rollers. Acceleration is very brisk.robertinino wrote:branyers
R
Isn't satisfaction good?
Branyers14
- Year: 2014 Forza
I probably will. Anyone wanna buy my sliders?you you wrote:Why not stick to the12g rollers then?Branyers14 wrote:I am, I have some 18g sliders on order. Honestly though, I am satisfied with the 12g rollers. Acceleration is very brisk.robertinino wrote:branyers
R
Branyers14
- Year: 2014 Forza
7500-7800rpm.sendler2112 wrote:What is the pulling rpm during an accel run?
- sendler2112
- Year: 2013 PCX150
Branyers14
- Year: 2014 Forza
You'd think so, but I also ran 10g rollers in my PCX with similar results. I liked the way they performed. Gets you right into the powerband.
Someone told me 100mph is attainable on the Forza. I just wanna know how.
- Mario
Down hill and flat on you belly with a 12 Bf wind in your back will maybe bring 100mp/h, or something like this,
May the Forza be with you!!
robertinino
how is the acceleration time 0-100 km with malossi and stock rollers?
De pulley in original variator 0-100km is about 10 seconds......
R
R
- Mario
The TechPulley clutch has arrived and is mounted, all fits well and first (short test run) impression feels good, grip moment of the clutch with full throttle has moved up 1000rpm, and easy ridding is still very doable.
Today I will do a good run with the Gopro mounted, this will be with the stock 21g rollers advised by TechPulley, later I will put back in the 18g sliders.
Short first impression clip
https://www.youtube.com/watch?v=UZMu3qW ... e=youtu.be
Whats in the box + some goodies (it's the idea thats count
Stock clutch
Stock vs 15% spring
Stock clutch
Stock vs 15% spring
- sendler2112
- Year: 2013 PCX150
The stiffer contra spring will raise the pulling rpm of any given set of weights so the 21gm might now act as the 18 gm did with the stock spring. My "1500 rpm" spring for the PCX was actually 40% stiffer than stock. It caused a slight loss of top speed and fuel economy due to the increased belt tension so I took it back out.
robertinino
mario thanks for the report...
R
R
Branyers14
- Year: 2014 Forza
Wow, looks a LOT lighter than stock.
- Mario
The video's with the TechPulley clutch
Boring
21g stock rollers / yellow CS springs / white PS springs / 15% TechPulley compression spring
Also boring
Till now the best setup ever
18g Dr.Pulley sliders / black CS springs / white PS springs / 15% TechPulley compression spring
Boring
Also boring
robertinino
Hi Mario thank you very much for your video and job......
Your last configuration: 18g Dr.Pulley sliders / black CS springs / white PS springs / 15% TechPulley compression spring is so cool, could you please tell me your sensations between this new configuration and the previous configuration 18 dr pulley sliders on the original variator.
R
R
- Mario
Hi Robert,
Both (all) setup's are with the original variator, the last setup feels the most sportier/responsive off all setup's that I have experienced till now, especially the in between time's 20-40 / 40-60 / 60-80
Mario
Mario
robertinino
Mario
so the 18 g dr pulley + new clutch is much better ( more responsive) that 18 g dr pulley and original clutch. 0-100 is less than 10 seconds?
Next step will be the air filter.....
What I m thinking is if change variator with Autisa could give the same result...
R
R
- Mario
Why don't you try the Autisa Robert so we can compare both setups, love to see your results.
robertinino
mario, this is what the Autisia responsable said to me by email:
I must inform you that we have not yet this variator ready. We are finishing the bell mold. As soon as it will be ready we will update on the website.......
- Mario
Tuned the front rim of my Forza, much faster on the corners
Next will be the rear rim for higher speeds
