which turn signal alarm will work?
- Color: red
i am a newbie; having a 2016 pcx 150 honda. i wish to install a signal alarm so i can hear a beeping sound when my directionals are on, but i have no idea which one would work on my scooter. if you can direct me to an affordable one that will work, i can then get it and have a friend install it for me. thanks for any help.
- Year: 18 300 xmax
Re: which turn signal alarm will work?
i mounted one on my xmax, my advice no matter where you put it, make sure the speaker is open to the air, otherwise the plastic can muffle it too much. Moved mine twice for better sound.
- Color: red
thank you. do you know which unit you bought for the signal beeper device?
- Year: 18 300 xmax
the pcx will be diff, so what I bought will not be best for you. I believe someone here said the etire flasher module on a pcx can be replaced with an audio one. i mounted this one:
https://www.amazon.com/Yuesonic-Univers ... 202&sr=8-5
I don't know if the 2016 model uses the same 2 pin flasher relay as my 2013 model, but I purchased one that sounds like a truck backing up. It was fairly easy to install. The relay is located under the dash cover, which means that you have to have some plastic trim removal tools in order to get to it.
You will need to remove the windshield and the black dash cover. It should be visible then. If you can't determine which one it is then, just turn on the key and press the turn signal. You will hear the clicking of the relay easily enough. It is a little square box with two wires attached.
It uses a thick piece of rubber, like a rubber band but much thicker, to hold it in place.
Here is a round version with sound. I have one similar.
https://smile.amazon.com/Motorcycle-Mot ... 64&sr=8-22
