Hi all! New owner here.
I thought I would re-post my question here.
Interested in hearing from any owners that have changed-out their stock clutch for one of these aftermarket Kits.
How did it turn out? Any down sides to performance?
What and how much is possible with an updated clutch?
Is it worth it with the limiting factors that Honda built into the electronics?
Would you do it again?
Thanks Dr.k
After-Market Clutch kits
Re: After-Market Clutch kits
Hi, I recently swapped out the original clutch for carbon pads, stiffer springs and a machined housing . These mods coupled with roller weights of 12g and 10g work well on my 2020 adv 150 and give much crisper acceleration and still a top end of 116km . I bought the parts on line from lazada and aliexpress here in Thailand . Pcx mods are very common out here and parts easy to obtain . I had a choice of 3 types of clutch pads with the carbon being the most expensive and I suspect fastest wearing . I would consider the lighter rollers and a modified roller casing a better investment for the money as you will gain most for the least cost but that's just my opinion .
