CaptnJim wrote:A friend of mine bought some carbon fiber look duct tape. He taped a couple spars on one of his boats, and it looked good. He was careful about lining up the edges, etc. If all you want is the look, this might be an inexpensive alternative.
You know Cap'nJim, they make most things on youtube look harder than they are when it comes to the scooter but this... this is some seriously difficult medium to work with. First your object to cover needs to be stable, like a car or tree
Then you need to keep it off of itself after removing the backing. I think we can all do that but it doesn't stretch without heat and it melts if too hot. This delicate balance of holding the object, applying the material and not over heating it to manipulate around even the most casual curve whilst not creasing any part of it..... is maddening!
Where is this carbon fiber duct tape... if it has the typical adhesive it will damage the plastic. That is one attractive feature of the wrap, it effectively seals and protects things in time.
