Front Disc Lock - WHERE???
wangsuda
Color: Silver
Post by wangsuda »
I am in the land of bikes, here in Beaumont, CA. I have looked everywhere for a disc lock for my PCX. So far, no luck. No one has anything for the PCX.
Do any members who live in Southern California know of any shops that carry disc locks for a PCX? Additionally, do any Bangkok members know where I can get a quality disc lock? I am looking at the Xena X1, but will consider all models.
Thanks!
Re: Front Disc Lock - WHERE???
Only thing I know that the PCX and some other scoots need is a 6mm pin, but if you put the pin throught the larger cut-outs rather than the round 6mm hole, I believe larger pin and larger (stronger) locks should fit. Best see if others say why that is not possible.
Hold Da Kæft
Post by Hold Da Kæft »
Hold Da Kæft wrote:I'll be using this bad boy
http://www.sportsbikeshop.co.uk/motorcy ... prod/59283
So, that has a rectanguler 3mm x 5mm bolt instead of the round type. Not sure that would go through a 6mm diameter round hole? - are you placing it though the larger cut gaps in the disc brake?
Once again seems the UK succumbs to rip-off pricing - about £94 or less $ to £ and £130 UK!
wangsuda
Color: Silver
Post by wangsuda »
iceman wrote:Only thing I know that the PCX and some other scoots need is a 6mm pin, but if you put the pin throught the larger cut-outs rather than the round 6mm hole, I believe larger pin and larger (stronger) locks should fit. Best see if others say why that is not possible.
It is a good idea, but what is the next size? 6 mm x 22 mm is for the PCX. After that, the sizes really seem to jump.
Captain Tom
Post by Captain Tom »
This is the one I use on my PCX. Nothing fancy.
http://www.amazon.com/s/ref=nb_sb_noss? ... ity+2+Keys
