Today, suddenly, the fuel cap has become hard to screw and unscrew.
The rubber seal seems to be ok. What may have happened?
Fuel cap hard to screw and unscrew
Re: Fuel cap hard to screw and unscrew
Dunno. Find something else to screw?kar120c wrote:Today, suddenly, the fuel cap has become hard to screw and unscrew.
A bit of lubrication might be your friend or work on your wrist strength?
- Alibally
Use a bit of engine oil on the seal. Don't use petroleum jelly as it rots rubber, or so the guy at the clap clinic said.
- Year: 2015 Forza 300
Isn't better silicon for rubber seals?Alibally wrote:Use a bit of engine oil on the seal. Don't use petroleum jelly as it rots rubber, or so the guy at the clap clinic said.
kar120c wrote:Isn't better silicon for rubber seals?Alibally wrote:Use a bit of engine oil on the seal. Don't use petroleum jelly as it rots rubber, or so the guy at the clap clinic said.
If rubber seals are your bag then go for it. They can't catch fish though like the real ones.....
- Color: red
Yes, a bit of lube on the rubber gasket might help, if that's the jam. Have you dropped or otherwise injured the cap or filler neck? The cap's bayonet flange may be bent? Pretty simple to inspect and see what's up. If you know someone with the same bike you can try their cap and see if the trouble stays with your cap or the bike.
- Alibally
I wouldn't. Silicon destroys o2 sensors.kar120c wrote:Isn't better silicon for rubber seals?Alibally wrote:Use a bit of engine oil on the seal. Don't use petroleum jelly as it rots rubber, or so the guy at the clap clinic said.
See this. http://m.gendan.co.uk/article_17.html
Solved spraying WD40 on the rubber seals. Gasoline had hardened the seal
