Battery Charging - how long ?
bunnykins
Post by bunnykins »
i have never had a problem starting my pcx until a few days ago. it just turns over but wont start so i guess battery flat as the lights dimmed.
i have a solar battery charger i bought to use to charge my caravan battery. so i hook it up to the pcx battery [ i think charge rate is 2 amps ]
how long will it take to fully charge the battery ? i dont have a volt meter and there is no meter on the solar charger.
is the pcx battery a 12 volts ?
thanks
Year: 18 300 xmax
Re: Battery Charging - how long ?
At 2 amps, I'd let it go certainly a few days of sun.....batt maintainers are small, not really a charger.
Be aware a batt that is dead is damaged permanently in a partial way, longevity is compromised.
davenowherejones
Color: Silver
Post by davenowherejones »
2 amps sounds like a lot for a solar charger, it might be 2 watts. I have a solar charger that is 4x8 inches that I leave on my bike all winter.
What are the dimensions of your solar panel?
Some of the bigger panels put out 2 amps.
bunnykins
Post by bunnykins »
It says 2.4 w @ 17.5v dimensions 347@215@14mm
Might be worth pulling the fuses for the lights to see if that frees up enough current to get things going.
bunnykins
Post by bunnykins »
does the pcx have an alternator ?
bunnykins
Post by bunnykins »
i have already got battery out so have just connected the battery to solar charger, perhaps i'll leave it charging for 2 days but disconnecting it at night.
bunnykins wrote:does the pcx have an alternator ?
Yes.
