These bulbs boast three times the light output of halogen without the high heat and about 1/2 the power. Appreciate thoughts and comments Thx
https://www.amazon.com/Yosa-Headlight-C ... ED-HS5-18W
LED Headlight Bulb (HS5) ??
Re: LED Headlight Bulb (HS5) ??
2000 lumens wouldn't be anywhere near 3x the light output from the stock lights (guessing minimum 1200 lumens, happy to be told otherwise).
Another problem I encounter when looking up LED lights is that you never see the plug on the pig tail, so do you need to solder a plug onto them?
And then you have the way our reflectors are setup for a particular light pattern, typically ball or arc type. These have 3 pinpoints of light. Eh?
I gave up and ordered xenon gas bulbs which claim a modest and more realistic 30% increase in light output for the same wattage. Not sure about heat?
When I've used xenon gas bulbs in my cars over the years, I could see my lights reflecting off sign posts further away, but otherwise much the same.
My next order will be some super bright Cree LED lights to replace my parkers, in the hope I get some more spill light out to the sides and under the high beam.
- easyrider
- Color: blk
Comparison. LED vs. Halogen
LED Halogen
Brightness 2000lm 600lm
Bulb Life Span 30000hrs 300hrs
Power Consumption 18w 30w
http://www.hdbright.com/hi-power-hs5-18 ... p-618.html
Looks like plug and play.. ?? Don't see any connection plug though ???
LED Halogen
Wow, my bicycle light is 1200 lumens and similar brightness to halogen.
That just looks like banana connectors. Where would you get the plugs from?
