2013 PCX 150.
I'm 345lbs and I've heard that the stock shocks are nothing to write home about.
I'm here to try and gather a few suggestions for new rear shocks. Mainly all I've heard are YSS and NCY. Is NCY worth the $? Should I replace front ones as well? This is my first scooter/bike so I'm learning from scratch.
Thanks in advance,
Jacob
Suggestions on new shocks
- jacob2cold
- Color: Navy Blue
- honkerman
Re: Suggestions on new shocks
I like my NCY's. Tbh, as shocks go, they're priced just about right. Getting them set up takes a little bit, but once done, they are good.
I do not have the matching front forks as yet, but plan to get them once I have the extra cash.
I have heard that YSS has various types based on how much weight it will be carrying and how adjustable you want them.
http://www.powerbypcx.com/en/accessorie ... v2-v3.html
and
https://bikerzbits.com/yss/
and
- jacob2cold
- Color: Navy Blue
honkerman wrote:I like my NCY's. Tbh, as shocks go, they're priced just about right. Getting them set up takes a little bit, but once done, they are good.
Thanks for that. Are front forks just as important as the rear shocks? Also, is there a way to find when looking at shocks what the suggested weight limit is for them?
- Oyabun
- Year: `12,`15,`19
- Color: black&black
The NYC front forks are cosmetically a lot bling-er, but using the same stone age damper rod technology as the stock.
Generally on a scooter the rear has more weight distributed there, but raking care of the stock is quite important also.
For your weight I'd suggest an aftermarket spring, and a pair of cartridge emulators anytime over a bling fork lower tube.
as a matter of fact the brakes might be very happy about a healthy boost too - which can come in a form of fresh DOT4 fluid, sintered pads, stainless braided lines and brake disc upgrade.
- jacob2cold
- Color: Navy Blue
Oyabun wrote:The NYC front forks are cosmetically a lot bling-er, but using the same stone age damper rod technology as the stock.
Thank you. What are cartridge emulators? Lol
- flyingzonker
