That said though, lots of dealers will skimp out and do nothing but the bare minimum.gn2 wrote:First service involves the final stage of manufacturing quality control, everything on the scooter is supposed to be checked thoroughly for security and correct adjustment/operation.
It is probably the most important service your scooter will ever have.
If you know your dealer is reputable and think they will actually do the full inspection and valve adjustment, by all means, you should have them do it. Otherwise, if they seem shady or if you think they will cut corners, do the oil change and valve adjustment yourself.
For reference, here is the maintenance intervals for the PCX: http://www.hondapcx.org/viewtopic.php?f=15&t=323
