Page 2 of 3
Re: How-To Adjust Combination Brake Cable
Posted: Mon Jul 23, 2012 8:53 am
by HispanicSlammer
I have a good set of tools but have never come across those plastic removal tools, please where did you source them?
Posted: Mon Jul 23, 2012 1:43 pm
by maddiedog
There's a whole bunch on Amazon:
http://www.amazon.com/s/ref=nb_sb_noss_ ... c+pry+tool
You'll probably want larger ones, the ones for electronics disassembly will be too small. I'd imagine the ones for the car av removal should work well though.
Harbor Freight tools has a cheap kit too, if one is nearby your house.
Posted: Mon Jul 23, 2012 8:10 pm
by EddieC
yep! amazon is the way to go!
Posted: Mon Jul 23, 2012 8:47 pm
by ese12105
Sure is! And I just tried out amazon's new local delivery option. If they have the item in stock and you live near one of their warehouses, you can have your item that same day. Ordered in the morning and had my package at my doorstep just after I got home from work. Pretty neat. And only $10 for my order.
Posted: Thu Sep 13, 2012 10:43 pm
Timely fix & Excellent "how to/photoshoot" EddieC.... and guess what? I've got the tools Yeh!
You had a rough time at the start, but success was yours in the end plus savings in the pocket! Be proud
Thank ya!
oh, that hidden adjuster
but it does prompt one to do other mods once "in" there i.e. louder horn, glove box socket etc., etc., etc. I got some of that "to do list" stuff calling my name, but it's still summer
Posted: Sun Sep 23, 2012 11:18 pm
by Urbanian
How is adjusting the “combination brake cable” different than adjusting the rear brake cable?
A few days after getting my scoot, I discovered the parking brake wasn’t holding, so I adjusted the rear brake cable at the rear tire. It took a couple of adjusts before the parking brake held the bike snuggly without being too hard to set. Did it all with my fingers, no tools involved.
Was there a different adjustment I should have made? Is the combination brake cable separate from the rear brake cable?
Posted: Mon Sep 24, 2012 12:47 am
by EddieC
the combi brake cable is just the link from the brake lever to the mechanism that actuates both brakes. To adjust the rear brake effectiveness, such as parking brake effectiveness, you would want to adjust the nut at the end of the push rod on the rear brake. Sounds like thats what you did. =]
Posted: Thu Nov 22, 2012 8:14 am
by Cracksta
Thought posting here would be ideal since my question is regarding the CBS.
My CBS wasnt great or even made that much different without applying front brake too but after a service, I'm sure they adjusted mine so now the CBS brake was alot better, required less pressure and actual stops the bike.
After 2 weeks it seems it may have loosen as the sharp braking has been reduced to 'a bit better than factory'.
Can the % of brake power be adjust for CBS, i.e. i dont know what ratio is it but i'm assuming its maybe 40/60 front/rear?
I havent checked my CBS fluid yet, just worried that if i adjust again and it feel loose again within a month, I dont want to keep at it and stretch the cable.
I commute on my bike daily.
thanks
Posted: Mon Nov 26, 2012 11:31 am
by maddiedog
The rear brake has an adjuster on the back too, if you tighten it, you'll get more rear brake than front, effectively adjusting the ratio. The cable stretched a lot on mine too -- you're probably feeling the rear brake cable, rather than the cbs cable stretching. It should get better and stay stretched after the 2nd or 3rd adjustment.
Posted: Tue Dec 24, 2013 4:45 pm
by gohjohan
Thanks for the photo for the plastic removing tools. I bought a set yesterday because I now know what they look like
Re: How-To: Adjust Combination Brake Cable
Posted: Thu Oct 19, 2017 7:31 pm
by BubK
I have this problem but I can’t see your photos and am clueless how to remove the components you describe. Is there a way to get this post with the picture visible?
Posted: Thu Oct 19, 2017 9:02 pm
by BubK
BubK wrote:I have this problem but I can’t see your photos and am clueless how to remove the components you describe. Is there a way to get this post with the picture visible?
Never mind, I got an add-on in Chrome to post the images. Thanks for this tip.
Posted: Fri Oct 20, 2017 1:14 am
by homie
What add-on for Chrome did you find that can unlock unpaid photobucket images please
Posted: Fri Oct 20, 2017 1:24 am
by TheMaverick
homie wrote:What add-on for Chrome did you find that can unlock unpaid photobucket images please
My guess is "none".
There is an add-on for phpBB though that backs up linked images and automatically re-inserts them if the original disappears (we used to use it when I was the admin at the Cambridge in Colour site).
Might be handy here.
Posted: Fri Oct 20, 2017 9:39 am
by BubK
It's called Photobucket Hotlink Fix. I don't know how it works but I got the pictures I need to take on this task and that was all I was hoping for. Good luck to others. I haven't found any other posts that addresses the rear brake lever problem as directly as this one.
If you've tried this before and it didn't work, the add-on mentions a problem that has been resolved. I'm using Windows 10, if that matters, I don't know.
Posted: Fri Oct 20, 2017 10:50 am
by homie
BubK wrote:It's called Photobucket Hotlink Fix.
Ah Ha! thanks for the follow up. This is good news and the google chrome extension puts a thumb in the eye of photobucket as well it should.
WORKS! I can now see all the blocked images in this thread
I guess you need to be using google chrome or firefox to get use of the extension. Very simple just click add to chrome.
Do you want me to put up the stand alone post and try to get admin to sticky it? Don't want to take credit for this discovery but I am taking it to my other forums immediately.
https://chrome.google.com/webstore/search/hotlink
Posted: Fri Oct 20, 2017 12:33 pm
by BubK
Whatever helps poor saps like me when the only relevant post I'm aware of for this problem won't give them the photos they need is fine with me.
Posted: Fri Oct 20, 2017 1:11 pm
by homie
BubK wrote:Whatever helps poor saps like me when the only relevant post I'm aware of for this problem won't give them the photos they need is fine with me.
I apologize for the lack of brake repair posts and video's. You won't find much in my YT channel either about brakes because of liability. I refer you to the service manual and perhaps others should too. Do you have the SM for your scoot because we can get you that
MANY THANKS to you for fixing the photobucket issue man! Cheers going up across the boards
Posted: Fri Oct 20, 2017 5:46 pm
by BubK
The SM I've found on the internet doesn't seem very detailed and I can't save it as a pdf, which is my preference in case I don't have a good signal. I'd appreciate whatever help I can get. I'm real green at such projects but I'm willing to give it a shot.
Posted: Fri Oct 20, 2017 5:52 pm
by BubK
I have a 2016 pcx150 but I don't know if there are any significant changes between model years. In others words, does one SM serve all?
