Page 2 of 2
Re: Performance parts
Posted: Thu May 01, 2014 8:07 am
by pcx125
Many many thanks guys
Posted: Thu May 08, 2014 7:33 am
by Alibally
I got a set of 10g Dr pulley sliders to try. It doesn't seem to make a lot of difference from the 13g ones I had in except for revving hard now when you accelerate. I'll give them a go for a while but will probably put the heavier ones back in. I am not wanting run about with the thing screaming its head off all the time. It's not good for the engine or the fuel consumption for that matter.
Posted: Thu May 08, 2014 7:50 am
by pcx125
Thanks for your updated. I already ordered 10g Dr pulley sliders and it will be arrive soon
)) I may not install it the
I may need more infor about malossi multivar 2000 with the 10.5 gr weights now
Posted: Thu May 08, 2014 7:55 am
by Alibally
If you've ordered them then give them a go, you might think they are fine. It only takes 20-30 mins to fit them so what have you to lose.
Posted: Thu May 08, 2014 8:09 am
by pcx125
I also still looking for some tools to remove variator as well
Thanks
Posted: Thu May 08, 2014 10:49 am
by Alibally
I made one. Looks like this.
Posted: Thu May 08, 2014 5:28 pm
by pcx125
thanks Alibally
Posted: Sat May 31, 2014 9:39 pm
by maddiedog
It wasn't worth the effort for me to build a tool, especially when a premade one is only $20. Here's the one I use to get off the clutch or variator on any scooter I'm working on:
http://www.amazon.com/gp/product/B000HS4NA8
Posted: Sun Jun 01, 2014 12:51 am
by Mgalutia88
Malossi multi var is good but daytona variator provides great acceleration and a higher top speed along with it. I think it's around 3-4kph higher top speed.
Posted: Sun Jun 01, 2014 4:09 am
by Alibally
maddiedog wrote:It wasn't worth the effort for me to build a tool, especially when a premade one is only $20. Here's the one I use to get off the clutch or variator on any scooter I'm working on:
Mine cost me nothing as I had the raw materials lying around the garage.
The bought tools are stronger looking though but the home made on works fine.
Posted: Mon Oct 20, 2014 8:02 pm
by 6ftMach1Girl
Mgalutia88 wrote:Malossi multi var is good but daytona variator provides great acceleration and a higher top speed along with it. I think it's around 3-4kph higher top speed.
Where did you get your Daytona variator?
Posted: Mon Oct 20, 2014 10:26 pm
by pcx125
No, I used Malossi multi variator with 10.5 grams rollers and very happy so far .
