Drive wheeling spinning on idle - Normal?
chigman
Re: Drive wheeling spinning on idle - Normal?
Post by chigman »
Whilst idling and on center stand, my rear wheel slowly rotates on a 125cc uk machine.
I just went and cleaned the scoot as I got caught in a horrendous thunder storm en-route to work this morning (2.30am!) - I'd left my waterproofs at work too as the forecast was for slight showers 7pm the next day :( - took ages to get from atlantic drenched look to fell in a puddle look :)
Checked the rotation of the rear wheel both ways again - seems fine, no noise. Lucky I guess.
2011 PCX 125 bored out to 170cc... Rear does not spin when idle on the centerstand.
It's just clutch engagement. The fresher your clutch is, the thicker the pads are, and the more likely they'll just barely catch at idle. A lower idle or more clutch wear will stop the spin. The idle on the PCX is not adjustable, so no worries there.
As long as the bike doesn't try to lurch forwards at idle, it's perfectly normal and you have nothing to worry about.
Mines only now done about 1500 or so miles - not seen the rear wheel rotation at any point, but only had the bike idling on the center stand twice (1st time about 2 months back). You say there is not idle adjustment on the PCX? But, the service chart mentions idle speed check? (I thought there was a rotational adjustment somewhere on the rhs of the bike? - not sure where I got that).
iceman wrote:I seem to be in the minority with a rear wheel that does not spin when idling on the center stand, and no real noise to be heard rotated either way (just a very quite noise rather than pure silence, which being heavy with bearings I think is fine). I wonder if there is a difference in UK/US models re. the additional brake thingy US models have and how they are setup? Many say the parking brake was useless out of the dealer, so maybe the rear wheel is just a bit more free/slack than some UK ones?
Well here is what I get cold or hot, and my parking brake is perfectly adjusted.
Steph
Year: 2013 150cc
Color: Black PCX
Post by Steph »
Finally checked this out. Both our PCXs have a slow rear wheel rotation while on the center stand. This with a cold motor. Course forgot to check when warm.
Thanks!
Homie/Steph, was "Any" noise heard while scoot was running on CS and spinning?
Also...Do you hear any noise when You move your scoot (with the motor off and in as little as ten feet?)
WhiteNoise wrote:Thanks!
the motor running noise just like in vid... should I be listening closer?
I used to hear all kinds of creaking and whining from the steering column where cables are bottle necked (when rolled around) but that was easy to fix by passing a little WD-40 on a rag on about every rubber coated cable running through the front fender well.
Steph
Year: 2013 150cc
Color: Black PCX
Post by Steph »
No unusual noises such as a mechanical malfunction. The motor running may cover lesser noises. No unusual noises when pushing the scooter with the motor off either.
Are you hearing strange or worrying noises then WhiteNoise?
binje
Post by binje »
The rear wheel on my 2011 UK PCX 125 rotates as well. Looking at homie's video, mine probably rotates at half that speed on idle on the CS. I see it every day simply because I leave it on for a min or two to warm up.
Incidentally homie... Kudos on how clean that bike is...spotless :) :) :)
2011 Honda PCX 125
So you start the bike before moving off the center stand? I see people do that but thought the slight shock of the bike coming off the stand and onto wheel/suspension may not be good for things, esp. with the stand attached direct to the engine block.
