SpeedAndStyle,speedandstyle wrote:I have done some vinyl wrapping and the 3M DiNoc is the best. The carbon fiber not only looks cool but has a neat texture too. I wrapped the front fender on my old Yamaha Zuma.
I also used two pieces to do my fender but hid the seam where it mounts so it couldn't be seen. Also the CF pattern will distort in areas where you have to stretch it a lot{major curves}. Heat is your friend when wrapping anything other than a flat surface. A good hair dryer set on high works great. DON'T use a heat gun unless you are super careful as it gets the vinyl wrap too soft and never when working on a plastic part. The adhesive is pressure sensitive so make sure you fully burnish the vinyl into place. The adhesion promotor{3M calls it a primer} does help.
Fellow zumaformus guy too! I miss my zuma, but the pcx isn't a bad daily drive at all!
