Re: dem0nk1d's pcx 150 (Slammed, streched and legit)
Posted: Wed Apr 20, 2016 7:28 pm
Yes it's rattle can, but it's all about the prep. All painted panels sanded with 220, and then i went over with the gray scotchbrite pad with soapy water. I then let everything air dry, and then go over each panel with a degreaser. I used a paint that bonds to plastic, so i didn't need to use a promoter for adhesion.
The color is a "Satan" so it does have a very low gloss to it and isn't super flat.
Front forks are stock with my stock springs chopped. The shock tubes got scuffed down with some sandpaper and I used a lacquer black from a can. 90% of is done in the prep work.
