I finally figured out what you mean. . .Jack Nicholson as the Joker with the "He's been using Brand-X" quote.Marvel Mystery Oil
The "Bucket List" one of my all time favorites. And "Easy Rider". . .
I don't do much driving these days, so I pay someone to service my Jeep once/year because I CBF'd doing it myself now I'm getting older.PCX150Rider wrote:Yeah. . .there's a bunch of stuff in it including boron. . .the wintergreen is for scent but it does have cleaning properties. And there's a couple of different types of benzene as well I think. The list goes on and on and all the details. . .it may not be for everyone but I gotta say with a grin it did stop the ticking valve in my Jeep. The engine I have in it is a 4 cylinder and it's known to have carbon issues. Chrysler posted a Tech Service Bulletin back in 2004 to use a different spark plug to help prevent the problem. Carbon buildup seemed to be occurring with people who made short trips on cold days and didn't give the engine enough time to properly warm up. . .hence carbon problems. So after I started using the Marvel Mystery Oil in the oil and gas the problem permanently went away in about a week. When I did the first oil change after that it looked like black paint. . .tons of dissolved crap in it. That was when I had around 30,000 miles on it. Subsequent oil changes were never as dark. . .just what one would expect. . .plain old dirty oil. Now I've got close to 100,000 miles on it and it runs great. The front fenders are rusting but other than that I can't complain.![]()
On another note. . .I've been using Castrol for years in my machines. . .just Castrol. I used to use what they called 20w50 Castrol Motorcycle Oil (non-synthetic) in my KLR, but now use the 10w40 conventional (non-synthetic) in both my KLR and Suzuki GSF 1200S. I generally change the oil twice a year and the filters once a year. I found the 20w50 was a bit too much for the KLR and I just started buying 10w40 by the case and used it for both bikes with good results.
I was thinking about sticking with a Castrol product for the Honda PCX when I got it and was going to bring up the subject at the time but from what you are telling me the "Edge" product is the way to go eh?. . .what do you use in yours. . .the 5w30 or 10w30? And would you say it was good from the git go once the factory supplied oil was changed out? Once I start with an oil I stay with it as to avoid non-compatibility problems with other brands/formulas. I planned on using synthetic in the PCX but have heard pros and cons about break in issues.
Yes, it's MA. Here's a spec sheet from ExxonMobil that gives all of the approvals for all of their current Mobil 1 oils. I believe Honda suggests MB oil for the PCX, don't they?doletotodole wrote:This is MA i guess? can't see MB or MA anywhere.
Fully synthetic.
Do you gents use this or other MA engine oil?
Is it better than that recommended on manual?
I am planning for a long haul trip with my new PCX, to Tibet, then desert, then Xinjiang then back to eastern seaboard at south China.
Does this oil sustain the long trip?
Thank you, gents.
Mobil 1 also cleans out the inside of an engine, as will most dual-rated oils (15W-40 for example, although more slowly). Some cleaning comes from base oil chemistry, but usually it's the additive package that does most of the work.chicaboo wrote:... If you want to get silly about it, the only oil I've seen clean the inside of an engine is Castrol Edge.
Is that what you want from an oil? I don't know, but it's very impressive for before and after shots.
I bought a 1990 Saab 900 with 113,000 miles on it. The previous owner had always used conventional oil, so I continued until I learned about true syn oils. I had been a life-long Castrol user, but switched to Mobil 1 full syn at 120,000 miles. I ran Used Oil Analysis for several years on that car, & learned that with the right Mobil 1 oil, I could go 20,000 miles between oil changes (I would change the oil filter at 10,000 miles). The car has been on a strict 20,000 mile Oil Change Interval for the last 10 years. My son's now driving it, and it has over 300,000 miles on the still-original engine & transmission.PCX150Rider wrote:... Now I've got close to 100,000 miles on [the Jeep] and it runs great. ...
... Once I start with an oil I stay with it as to avoid non-compatibility problems with other brands/formulas. ...
Some people just want the slippery stuff, and never see the inside of their engines. By your own account, if you're using full synthetic, it's all good.Eiron wrote:And yes, that's certainly what I want from my oil. If your oil stays clear & clean, then all of the combustion byproducts are adhering to your engine's components. I'd much rather have nasty looking oil that's carrying around all of the dirt & varnish, than have crystal clean oil leaving carbon, gum, & varnish layers throughout my engine.
Thanks for the info. . .I'll add that to my list of pros and cons when I get ready to do the first PCX oil change.I had been a life-long Castrol user, but switched to Mobil 1 full syn at 120,000 miles.
