Page 2 of 2
Re: Hot wired Stolen PCX125 2014 , 4-pin connector missing
Posted: Thu Sep 14, 2017 10:55 pm
about...."sitting tight for an update"
No worries, I'm hanging in and hanging on
Posted: Sun Feb 18, 2018 1:00 am
by St.Clair
How didi you get on with this Part by the way. Did it show up and fit. I am also trying to locate this part for a project I am working on. Can you remember the UK supplier.
Posted: Fri Feb 23, 2018 3:06 pm
by flyingzonker
I wish you luck.
Probably the best luck you could have is to get out of London. Happy me to live in a town that is big enough to be interesting but too small to support a lot of sophisticated felons. The sharp cats and big timers all head for Megalopolis.
Posted: Wed Mar 21, 2018 10:13 am
by Patkin3484
I realise this is an old post but it may help others. in the absence of a plug, you can dremel or cut the plastic shroud from around the 4 pins. then you can simply use 4 insulated male connectors pushed over each pin. you could even solder the wires to the pins and use an aftermarket 4 pin plug and socket instead.
Posted: Fri Apr 13, 2018 5:27 pm
by raf186
Hi Guys
Any update regarding this project? My PCX was hotwired and I am looking for some help please
