Thanks for the info Robbie.
How did you get the combination of the two to work please? Does the muff interfere with the operation of the throttle? Does the cable for the right hotgrip hit against the muff?
Thanks all :-)
Oxford hot grips and Tucano muffs.
Robbie
- Color: Grey
Re: Oxford hot grips and Tucano muffs.
I installed heated grips first and muffs after. There are a couple of different types of muff and I have the r362x which don't fix to the end of the grips. The r363x muffs fit different and I can't comment on those.
I took no special precaution and it all worked together just fine. Had to cut the lever slots slightly bigger in the muffs to get them over the ball end.
Result is toasty hands even over the last week or so cold snap. Only had my grips on low - the bar muffs really make a massive difference.
