Yes it can, check your private messages.BubK wrote:does one SM serve all?
How-To: Adjust Combination Brake Cable
Re: How-To: Adjust Combination Brake Cable
Repair went without a hitch. Thanks to you I've gone from having no clue what to do last weekend to repaired and delighted this weekend.
BK
All things can be done with a service manual. You might not have the time, tools or patience but they can be done
Glad you had a good ride. I'm going to keep getting out there until it gets below 50 degrees. Many good days left in the Chicagoland area yet.
- dembones
- Year: 2015 Forza
- Color: 2016 PCX
Just did this job and can confirm that on my newer 2016 model there are some slight changes (plastic pat tabs, the actual adjuster is moved to a slightly easier location albeit still under the fairing.) My thanks to the OP for his guide as it did prove very helpful!
