Page 3 of 3
Re: How much work is it to install a larger throttle body?
Posted: Tue Jun 02, 2015 1:01 am
by Valiant
Suppose I'll keep that in mind for the clutch, because if I can get this trans issue sorted out and the throttle body installed, I'll definitely go back to that KN Planning Torque Driver.
Posted: Sat Jun 06, 2015 5:25 am
by Valiant
Well, got my variator holding tool in today. That's good.
Only problem is trying to find some time to work on it in between classes, work, assignments, quizzes, and studying for my next exam.
Posted: Sat Jun 06, 2015 8:42 am
by fish
Valiant wrote:Well, got my variator holding tool in today. That's good.
Very few will earn a livable livelihood fixing scooters.....focus on the studies!
You'll eventually earn enough to hire some other bloke to fix your wheels.
Posted: Tue Jun 09, 2015 8:25 pm
by Valiant
I wouldn't say money is the big limiting issue. I could afford to buy a brand new CB300F right now, just that I wouldn't have anyplace to stick the PCX.
I also had my PCX die on idle today at a stop light. It typically does that maybe once a month, so the idle isn't completely stable in its current state. Not sure if that's because the larger throttle body isn't installed.
At this point, even if my transmission fix goes well, I'm not entirely sure it would be worth any further investment in time and money to try and get this thing running right, either by completing the install or swapping back to stock.
Posted: Sat Aug 01, 2015 5:31 pm
by Pcxdemon
Forza 300 throttle body looks indentical to early Pcx and yuminashi tb. The only diff is and man,this was just for you but bit late valiant, it's operated via double cable just like your new pcx one, so it seems it would have been a straight swap for 34mm tb! That would have been an upgrade...
