Page 4 of 5
Re: Valve adjustment
Posted: Sun May 10, 2015 11:57 pm
by MikeP
I have found out in the past that when I check the oil at the service station the concrete pads are not always level as they should be. If I use a particular pump, the oil level reads the same each time. If I use another pump, my oil reading can be way off. Although visually the pads look to be very close to level. Hence I have gotten a "feel" of the oil level as normal just so long as it is on the dip stick to a marked degree.
Lastly I always check the oil at each fill up, even if I am in a hurry. It only takes a second and its the perfect time as the engine is hot and will get the best reading this way.
There must be a logical reason as to your very low oil level reading since you are not showing any leaks.
Good luck!
Posted: Mon May 11, 2015 1:33 am
jkautz wrote:It's definitely not losing oil. The drain plug is tight and no oil residue present around it. The screen plug is tight. I'm going to start checking it daily after my commute to see what is going on. The scooter was at WOT on my 50 mile ride home after picking it up so id figure if it there was a lack of oil the engine would seize up and seize up fast.
Any competent dealer would check the oil after setting the valves.
Posted: Mon May 11, 2015 9:12 am
by fish
DO drain that overstressed oil out and put in fresh.
Not much can be done about it now - after a call to the dealer to see if they noticed anything unusual when they did the valves.
Keep an eye on the dipstick.
A couple of explanations come to mind ...but non that help the situation now.
Can a HONDA run 50 miles WOT on a cup of oil? Might have.
Keep us posted.
Posted: Mon May 11, 2015 10:09 am
by jkautz
I'm going to drain it and refill. I have no idea why it was so low. I'll be making it a practice to check at each station stop. I'll keep you posted
Posted: Tue May 12, 2015 12:20 pm
by jkautz
I use Amsoil synthetic 10w30. You think Amsoil might be prone to burning more or shearing more? I thought it was good quality.
Posted: Tue May 12, 2015 2:34 pm
by iceman
While your at it, maybe check the final drive oil.
Posted: Tue May 12, 2015 4:57 pm
by jkautz
I'm a newb. Where can I check the final drive oil?
Posted: Tue May 12, 2015 6:22 pm
by fish
jkautz wrote:I'm a newb. Where can I check the final drive oil?
A pretty sorry youtube gear oil change video- but maybe you can get the idea of what/where we're talking.....
https://www.youtube.com/watch?v=6rRMcJ2 ... 30zP9nXoWF
Posted: Thu May 14, 2015 10:04 am
by jkautz
Thanks fish. All caught up on final drive info. Question for everyone. Is it okay to put 10w40 in the final drive? I'm thinking of using 10w40 in my oil rather than 10w30 due to WOT on my commute and warmer temps coming in the summer here soon. I ride spring/summer/fall with temps ranging from 45-60 in the morning up to 100 in the afternoon. But is it okay for 10w40 in the final drive?
Posted: Thu May 14, 2015 12:43 pm
by jkautz
bump......
Posted: Thu May 14, 2015 4:27 pm
jkautz wrote:Thanks fish. All caught up on final drive info. Question for everyone. Is it okay to put 10w40 in the final drive? I'm thinking of using 10w40 in my oil rather than 10w30 due to WOT on my commute and warmer temps coming in the summer here soon. I ride spring/summer/fall with temps ranging from 45-60 in the morning up to 100 in the afternoon. But is it okay for 10w40 in the final drive?
Yes
Posted: Thu May 14, 2015 4:39 pm
by jkautz
Thanks you you. Another question for my newbiness. I have Amsoil 10w40 full syn motorcycle oil, but it's rated JASO MA/MA2. Does the MB really matter? Or should I consider getting a 10w40 JASO MB?
Posted: Thu May 14, 2015 6:48 pm
by jkautz
bump.........
Posted: Thu May 14, 2015 11:31 pm
jkautz wrote:Thanks you you. Another question for my newbiness. I have Amsoil 10w40 full syn motorcycle oil, but it's rated JASO MA/MA2. Does the MB really matter? Or should I consider getting a 10w40 JASO MB?
No and if you wish
Posted: Mon May 18, 2015 10:43 am
by jkautz
Changed the oil this weekend to 10w40. Also checked the final drive and the oil was flowing out. The oil looked like it was in new condition so I didn't change the final drive.
Posted: Mon May 18, 2015 11:06 am
jkautz wrote:Changed the oil this weekend to 10w40. Also checked the final drive and the oil was flowing out. The oil looked like it was in new condition so I didn't change the final drive.
Not sure about that. I dropped mine out and it was clear enough but quite a few metal particles drained out
For the time it takes. 5 mins tops. I'd be tempted to
Posted: Mon May 18, 2015 11:25 am
by jkautz
Maybe on my next oil change I'll be tempted to drain it out. But the oil looked good after 2800mi. Maybe around 4k-5k ill change it
Posted: Tue May 19, 2015 12:11 pm
by maddiedog
Regarding the oil being low from the dealers, a lot of dealers don't check the oil right.
You're supposed to:
- Put the PCX on the centerstand on level ground
- Take out the dipstick, clean it
- Insert the dipstick. Don't screw it in.
- Take the dipstick out. Check the level.
My dealer omitted the "Don't screw it in" part and underfilled the oil. It's common. It won't kill your PCX. Just top off, and do the service yourself next time.
Posted: Tue May 19, 2015 1:49 pm
by jkautz
Glad to hear it won't damage the engine. I have since ridden it after my oil change and it's running better than ever.
Posted: Wed May 20, 2015 4:48 am
by fish
jkautz wrote:Glad to hear it won't damage the engine. I have since ridden it after my oil change and it's running better than ever.
Just a note, the final drive oil will pretty much always look good and light colored since it is not involved in combustion....like engine oil. After a bazillion miles it will look clean/clearish. Don't go by appearance....change per your maint schedule ...or more often if you like.
