Re: CVT mods for PCX 150?
Posted: Fri Mar 27, 2015 8:29 pm
				Just exercise some throttle control and limit yourself to 80-85mph instead of 90 and it should be sweet!
https://hondapcx.org/
Yes it works for me just fine. I just took the cover off and examined the belt... absolutely no wear on the belt and no gouges/scrapes where it might touch the cover, I could still see all the painted on numbers on the belt etc.Valiant wrote:That works for you? How long have you used the Yumi vario with the sliders?
As I recall, one member insists his belt was shredded because of that combo. Something to do with the belt rubbing against the back of the case. If the Yuminashi variator(or any other) already pushes the belt as far out as it will go, then I would think it's a very real issue if the sliders pushes the belt out even further, causing the belt to rub the case.
Bugger o.Odasshreddar wrote: Yes it works for me just fine. I just took the cover off and examined the belt... absolutely no wear on the belt and no gouges/scrapes where it might touch the cover, I could still see all the painted on numbers on the belt etc.
Also with the rollers I could do 80(speedo) on the stand, with the sliders it will do 81 on the stand.
yes just the variator, Gates belt and sliders... also don't forget the big tires, so 81 on the stand means in "theory" downhill with a tail wind I could do 85mph gps.Valiant wrote:Bugger o.Odasshreddar wrote: Yes it works for me just fine. I just took the cover off and examined the belt... absolutely no wear on the belt and no gouges/scrapes where it might touch the cover, I could still see all the painted on numbers on the belt etc.
Is the variator the only gearing mod you have? I'm getting the same speeds on the stand, but I also had the shorter gears installed, which should have made my top speed higher. Now I'm kind of wondering if my scooter shop put the rev limiter lower than the stock 9600 when they were programming the EFI.
dasshreddar wrote:yes just the variator, Gates belt and sliders... also don't forget the big tires, so 81 on the stand means in "theory" downhill with a tail wind I could do 85mph gps.Valiant wrote:Bugger o.Odasshreddar wrote: Yes it works for me just fine. I just took the cover off and examined the belt... absolutely no wear on the belt and no gouges/scrapes where it might touch the cover, I could still see all the painted on numbers on the belt etc.
Ah, but it would be much lower in real road conditions right? IIRC, homie actually lost some speed because it takes more power to spin the larger tires.dasshreddar wrote: yes just the variator, Gates belt and sliders... also don't forget the big tires, so 81 on the stand means in "theory" downhill with a tail wind I could do 85mph gps.
