Page 5 of 5
Re: NCY Variator, Face Plate, 13gr Rollers, Belt for 2013 1
Posted: Tue Jan 20, 2015 12:43 pm
by SECoda
Right between 7900-7950 rpm full throttle starting from 30 mph.
Posted: Tue Jan 20, 2015 1:06 pm
by sendler2112
7,900 rpm is just about ideal. You definitely don't want to go heavier. 12g might be slightly quicker 10-50 mph but not worth spending more money.
Posted: Tue Jan 27, 2015 11:13 pm
by typhon2222
I installed the NCY variator, face plate, and 12g rollers on my 2011 PCX 125 (approx. 4,500 miles), and gave her a new OEM belt at the same time.
Pulling RPM full throttle: 7800-7900. Max speed (flats, no wind): 62 MPH (GPS).
I've subsequently installed a second, identical set (NCY variator, face plate, and 12g rollers) on my new 2013 PCX 150 (approx. 200 miles).
Pulling RPM full throttle: 8100-8200. Max speed (flats, no wind): 65 MPH (GPS).
I would have expected both speeds to be faster. I'm also surprised that the 150 is only 3 MPH faster than the 125. And that their pulling RPMs are different, given they're both running the exact same setup.
Posted: Wed Jan 28, 2015 1:39 am
by Valiant
Those speeds sound about right.
I get maybe 68 mph(GPS) on my 2015 PCX 150 when going downhill, and maybe 63-65 on flats(though wind is a universal constant on this island). I need an aftermarket air filter and Takegawa Silent Sport Oval Exhaust to get me there.
The PCX is not a powerhouse, and it would also depend on rider weight, what you're wearing, etc.
I suspect your 2013 might be able to go a bit faster once you fully break it in and change out the oil.
The speed does seem a tad low given that your 2013 should have a gearing advantage over mine(by maybe 3 mph), I weigh 200 lbs, wear a bulky armored jacket, and I have saddlebags loaded with 25 lbs of chains and a top box. So I've got plenty of wind drag on me
Posted: Wed Jan 28, 2015 5:50 am
by sendler2112
typhon2222 wrote:I would have expected both speeds to be faster. I'm also surprised that the 150 is only 3 MPH faster than the 125. And that their pulling RPMs are different, given they're both running the exact same setup.
It might be that the contra springs are a little different.
What is the rpm of the 150 at 65 mph?
Posted: Thu Jan 29, 2015 1:20 pm
65 mph??? Both my wife and i top out at 68 mph (gps) when we have new belts on out 150s. Right now she has a new belt, while my new belt is stored in my tailbox until i can change it out.
Posted: Thu Jan 29, 2015 2:01 pm
by SECoda
Mine did too with the stock parts but the 2015's are a little slower
Posted: Thu Jan 29, 2015 3:05 pm
by sendler2112
Depends how much someone is willing to tuck.
Posted: Mon Feb 02, 2015 8:09 am
by kalai1622
today I received the Advance Pro large Diameter 120mm, 14 Degrees of Angle. I noticed that on the plate writes with embossed letters: PCX 120x14. isn't it problem for the belt?? the surface of the drive face shouldn't be smooth??
Posted: Mon Feb 02, 2015 1:38 pm
I have a general question. I looked at the drive face on corsportusa.com and it looked different than this one at webike:
http://japan.webike.es/products/21354758.html
Are they the same drive face? If not, is one preferred over the other?
Posted: Mon Feb 02, 2015 3:39 pm
by kalai1622
Mel46 wrote:I have a general question. I looked at the drive face on corsportusa.com and it looked different than this one at webike:
check the fourth photo of the above link. It is the same as I described! about the embossed letters..
http://www.corsportusa.com/2010-honda-p ... rive-face/ this one?? it is not the same..
Posted: Mon Feb 09, 2015 9:19 am
by SECoda
I have been riding the Forza a lot lately but I took the PCX for a short spin yesterday with a friend with a Harley and that NCY setup really makes it accelerate like a Banshee. I don't know how long term belt wear will be but the performance improvement is really nice. I may have a gained a mph on the top end with some more miles on the new setup.
Posted: Mon Feb 09, 2015 4:56 pm
by Valiant
SECoda wrote:I have been riding the Forza a lot lately but I took the PCX for a short spin yesterday with a friend with a Harley and that NCY setup really makes it accelerate like a Banshee. I don't know how long term belt wear will be but the performance improvement is really nice. I may have a gained a mph on the top end with some more miles on the new setup.
It'll accelerate like a Banshee, but only up until the weights are locked out, which is about 50-55mph. While I can easily keep up with if not entirely blow past all cars and bikes under 500cc, it's an entirely different story on the highway where I'm following behind a really beat-up looking 250cc dualsport and I'm only slowly catching up on full throttle when I suspect the other guy is cruising comfortably on 3rd gear at a little over half throttle.
Still, having an aftermarket transmission really makes you less of a nuisance on the highway because merging and changing lanes is easier with the faster acceleration.
