Instructions For Installing Honda's 2019 PCX OEM Windscreen
Posted: Mon Mar 30, 2020 9:49 pm
by PeteyDelivery
I purchased one from Blackpool Honda, UK/ Ebay.com USA. It didn't come with instructions! It's pt # 08R70-K96-T00 Body Mount Shield Kit. I couldn't find a pdf online. Any help would be appreciated. Thanks!
Re: Instructions For Installing Honda's 2019 PCX OEM Windscr
Posted: Tue Mar 31, 2020 9:21 am
https://www.google.com/url?sa=t&source= ... x7xIeT-Q_W
I don't know if this will help because it is in a different language, but maybe you can gain some insights by watching it.
Posted: Tue Mar 31, 2020 7:22 pm
by PeteyDelivery
Thanks, I saw that. He has the same model year and it's useful for removing the "V" shaped trim. (Even the Service Manual isn't that clear.) I can't figure out where all the Honda OEM hardware fits. RIGHT NOW I FOUND AN OIL LEAK! So it takes precedence. Mine is brand new, I just rode it home from the dealer and there seems to be engine oil leaking from the weep hole at the low point of the muffler where condensation comes out.
Posted: Thu Apr 02, 2020 8:24 pm
by PeteyDelivery
Dealer says oil came from the filler spout where the dip stick is, I guess I'll believe them. I was worried the exhaust valve seal was bad, contaminating the Oxygen sensor, catalytic converter, etc... (Phew!)
