Oil leak, or normal?
Posted: Mon May 20, 2013 7:50 am
by loudgonzo
This is with almost 3000 miles on the bike, has only had the 600 mile service done to it. Is this normal?
Re: Oil leak, or normal?
Posted: Mon May 20, 2013 7:51 am
by loudgonzo
1 more picture.
Posted: Mon May 20, 2013 8:06 am
Mine's the same.
Could be that the drain tube is full and overflowing from further up?
Posted: Mon May 20, 2013 8:13 am
by loudgonzo
1 more thing, it's been a while since I installed a givi e370 topbox. But how do you take this connector off? Does it pry off, or is it locked in somehow?
this picture shows the same type connector, and I just don't want to break or damage it.
Posted: Mon May 20, 2013 10:39 am
by loudgonzo
thanks gn2, will check the oil, actually replace it this week.
anyone have the solution for taking the connector off? does it just need to be pried off?
Posted: Mon May 20, 2013 3:18 pm
by SmellyTofu
You don't need to remove it to service it. Perhaps get the base off but just leave it hanging so you can remove the fairings (if you're doing the valves).
Posted: Tue May 21, 2013 11:15 am
by st3v4nt
loudgonzo wrote:thanks gn2, will check the oil, actually replace it this week.
Why would you want to remove it?
If you just want to remove the GIVI top box, just put the cap on connector provided by GIVI when you purchase the box.
If you want to remove the base you need to unscrew the flat plastic floor first, then remove it to expose four
bolt in base frame and then after you remove that bolt you then have access to GIVI bracket bolt.
You also need to disconnect the cable from GIVI to the tail light cable that can only be accessed when you remove
the tail grab plastic pannel.
If you insist to remove the connector you can access it from the under side of base frame. You need to remove the
connector lid first using small flat screw driver, then unscrew the cable terminal to remove the cable,
then you can remove the connector upper side.
Posted: Tue May 21, 2013 4:53 pm
by Pcxdemon
loudgonzo wrote:1 more picture.
Too me it look like you gearing oil is coming out somewhere around there,its def not an engine oil. Engine oil will get sucked thru the air filter before it come out of that clear tube at the back of airbox.
Posted: Wed May 22, 2013 1:25 am
by Pcxdemon
My advise is spray some degreaser on there and hose it down,then try to see where its coming from exactly..Hope this helps. :geek:
Posted: Wed May 22, 2013 10:06 am
^^^ I think that's a good suggestion (beginning point), can't hurt none ;)
Posted: Wed May 22, 2013 10:36 am
by ben
Thats never normal, 15000 miles and ive not got this. If you breather pipe is full then goo will leak out the bottom of the airbox (theres a little hole) but then tends to run down the front of the casing, seen that on several of the pcx at work. Thinking final oil is leaking...
Take it back to the dealer anyways before it becomes a problem...
Posted: Wed May 22, 2013 11:48 am
by loudgonzo
where is the breather pipe, and what would it get full of?
Posted: Wed May 22, 2013 12:16 pm
by ben
Clear tube with a crimped end off the back of the airbox . It get full of stray oil and like condensation, it fills up real fast when it's cold out. It mentions in the manual to clean it out when if fills. Most of the pcx I see have it full and goo leaking out the bottom of the airbox where it's overflowed.
Posted: Wed Jun 12, 2013 11:45 am
by maddiedog
I have similar goo around there on my bike, but it's from the road, not from leaking gear oil. I recommend you check your oil and gear oil levels just in case.
Posted: Wed Jun 12, 2013 6:17 pm
by hectyc302
Not normal I agree check where is coming from !!!
Pcx having a lot of lil issues it reminds me of my Chinese taotao and
I hate the lil problems thats why I got a Honda :(...
