				Suspension lift kit
				Posted: Thu Mar 28, 2024 6:24 pm
				by Mon-Eye
				So I ride on some rough roads and terrain quite regularly (4 miles  a day) and decided some extra ground clearance would help. Also got new shocks and fork rebuild kit on order too which should help too. So bought some 50mm rear shock extenders and I'm quite happy with the extra clearance. Bike seams to handle nicely with them on too but havent pushed it hard in the dry yeh.
				Re: Suspension lift kit
				Posted: Mon Apr 01, 2024 6:27 pm
				by maddiedog
				Nice mod. I bet that helps with cornering too - I always dragged the centerstand and lift would get it higher off the ground!
				Posted: Tue Apr 02, 2024 9:17 pm
				by Mon-Eye
				maddiedog wrote: ↑Mon Apr 01, 2024 6:27 pm
Yeh makes it turn in alot nice and makes it more agile too. Has added quite a bit extra clearance and both stands still work fine too
				Posted: Sat Apr 06, 2024 2:08 am
				by Lrhpkk
				Hi,
Off topic because I cannot PM the moderator.
Can someone please tell the moderator he has another spammer to delete: Bogdannmf appears to be an unwanted intruder.
Thankyou
				Posted: Sat Apr 06, 2024 6:22 am
				by airhead83
				Lrhpkk wrote: ↑Sat Apr 06, 2024 2:08 am
Hi,
Thankyou
In the upper right side of every page near your avatar, you'll see a set of 'quotation marks' (") and 'explanation mark'(!).
If you click on the (!) it will send you a "Report" page. Follow instructions from there.
				Posted: Sun Apr 07, 2024 9:09 pm
				by Lrhpkk
				Ah yes. Thankyou.
