Fastest PCX?
Posted: Fri Sep 20, 2024 3:00 pm
Hey guys.
I’m in the middle of a big build and I was wondering if anyone has any idea how much horse power or what times they’re getting out their modified bike? Here is a list of all the modifications i have made so far. Currently I am stuck what to do about the air intake as it’s still very restrictive and also I am having problems with the ECM.
150cc cylinder (135cc end volume)
CNC piston
Cam shaft
Crank shaft
API ECM
Fuel pump
Throttle body
Air filter
Airbox mod
Exhaust
BRC radiator
Final gear
Clutch/CVT
RCB wheels
IRC 70(80)/90-17 NT73
Yss front kit
Rear shock
Rcb brake lever
Steel line
HH pad
Floating disc
CNC piston
Cam shaft
Crank shaft
API ECM
Fuel pump
Throttle body
Air filter
Airbox mod
Exhaust
BRC radiator
Final gear
Clutch/CVT
RCB wheels
Yss front kit
Rear shock
Rcb brake lever
Steel line
HH pad
Floating disc
