2019 pcx crank position sensor
Posted: Mon Nov 04, 2024 1:49 am
				Need help!
I have an engine light come on and bike stalls,
Obd 2 scan says po335 which is crank position sensor ,or
5 long flashes and 2 short also saying crank position sensor ,
Does anyone know where this is ? I assume it’s the one attached to the stator with 4 prongs , will try and attach a pic,
I have called Honda and they can’t find a crank position sensor in the workshop manual , when this started it would start only on top dead centre and. Not stall,but no engine light ever came on whatsoever so I replaced the stator and sensor and that fixed it , 1000ks later engine light came on and it stalls, leave it 5 mins amd it will start again but not go for long, i then put the original sensor back on amd ran perfect for 40 kilometres , the boom problem is back, I do believe I had bad fuel in it to make this problem start as I turned it over maybe to much ,
The bike will always start as soon as it turns over , and doesn’t just turn over and never start ,
Amy help would be appreciated ,
Is this the crank position sensor ?thanks
