Page 1 of 2
Filling gas tank
Posted: Thu Sep 05, 2013 1:16 pm
by dustin91
My dealer told me to fill the tank to the silver bar that runs across the nozzle port. Being in NJ, all stations are full-serve only, and on my first fill-up, the attendant spilled some gas out because the nozzle didn't automatically shut off as it would in a car.
Does that bar keep the nozzle from going in to far? How does everyone else fill up their tank? So far, I just get to a station with one bar left before Empty, and add in a gallon before checking to see where the fill level is.
Just curious if others hold down the pump until when and if it shuts off automatically.
Re: Filling gas tank
Posted: Thu Sep 05, 2013 1:18 pm
by ~Cheap_Ride~
That doesnt work at the pump I use here in Sioux Falls. I eyeball it and leave an inch or so from the top.
Posted: Thu Sep 05, 2013 1:32 pm
by Bash On!
Auto shut-off hasn't worked for most of the bikes I've had at most of the pumps I've used. Safer to fill manually, knowing the size of your tank and slowing down the fill rate as you get close to full. Only filled up the PCX once so far but found the fuel level in relation to the silver fill indicator hard to see. Don't know how that will help you in Jersey, except to warn and instruct the pump jockey.
Best,
Bash On!
Posted: Thu Sep 05, 2013 2:01 pm
by strkngfang
I do as cheap ride does. I watch the pump gauge to 1 gallon & then baby the trigger to the crossbar. We are all self serve in OH.
Posted: Thu Sep 05, 2013 2:04 pm
by ~Cheap_Ride~
I find over filling is a bad idea. Gas expands and contracts so I leave room for it to breath.
Posted: Thu Sep 05, 2013 2:16 pm
Honda have already taken care of that, it is very difficult to get it really full and take up all the expansion room.
Posted: Thu Sep 05, 2013 2:33 pm
by Tom192
i fill mine right to the brim and then ride, get more smiles between fill ups then
Posted: Thu Sep 05, 2013 2:55 pm
Filled up is at the bottom lip of the filler neck. I spot check mine as well. I also have a small led light on my key ring for my "harder to see ya days" (my eye-specs help too)
and....You can wrap a shop rag around the filler for those shakey days
Posted: Thu Sep 05, 2013 4:33 pm
by dustin91
Thanks all. I did another fill-up today, and fortunately most stations will let me do it myself since it's just a gallon and they don't want to baby it. Looks like waiting for the bar before E, filling a gallon, and then spot-checking the last few pumps is the way to go. Appreciate the feedback!
dustin
Posted: Thu Sep 05, 2013 4:38 pm
Never worried about it tbh. Just fill and go
Posted: Thu Sep 05, 2013 5:27 pm
by gokidd
WhiteNoise wrote:Filled up is at the bottom lip of the filler neck. I spot check mine as well. I also have a small led light on my key ring for my "harder to see ya days" (my eye-specs help too)
There is no drain hose from the filler area, right?
I've only filled it twice ... once resulted in a slight over-fill.
Posted: Thu Sep 05, 2013 6:23 pm
The tank filler neck has a rubber gaiter surrounding it, this has a drain hose which empties out under the bodywork.
Posted: Thu Sep 05, 2013 8:20 pm
by dustin91
GN, that's what I learned on the first fill-up, thanks to an attendant with an itchy finger. From then on, I've done all the rest on my own. But that overflow area is a really good idea on Honda's part.
Posted: Thu Sep 05, 2013 8:47 pm
gn2 wrote:The tank filler neck has a rubber gaiter surrounding it, this has a drain hose which empties out under the bodywork.
........drain hose comes from the fuel tray, and then heads south (gosh I'm learning a lot!!
Posted: Fri Sep 06, 2013 11:12 am
by gokidd
Thank you, gn2.
I checked ... my drain hose had some haggis stuck in there.
(Quick tip: if you find haggis in your fuel drain DO NOT eat it ... it makes the gasoline taste weird.)
Posted: Fri Sep 06, 2013 11:16 am
The haggis is a very wily creature, they will squeeze into any warm little cubbyhole for a snooze.
A bit like an octopus, its amazing how something so large as the greater haggis can fit into the gaps it can, especially in light of its exoskeleton.
Posted: Fri Sep 06, 2013 11:17 am
by gokidd
gn2 wrote:The haggis is a very wily creature, they will squeeze into any warm little cubbyhole for a snooze.
Well-played, sir!
Posted: Fri Sep 06, 2013 12:05 pm
by Alibally
The legs are shorter on the left side of its body so it can run around hills easier.
Posted: Fri Sep 06, 2013 1:57 pm
Alibally wrote:The legs are shorter on the left side of its body so it can run around hills easier.
Endangered species now. Rarer than the panda in scotland
Posted: Fri Sep 06, 2013 4:12 pm
by gokidd
