Seat bag, tail bag, or roll bag that's NOT quick release?
Posted: Fri Nov 01, 2013 1:01 pm
by Kermit
Hi. I would love to attach a bag to my seat (I don't have a rack or any other mods), but I want it to be secure enough that I can leave it unattended and feel pretty confident that it won't be taken. (I would use a lock on the zipper for the bag's contents.)
It seems that as a matter of convenience, most/all of the bags that are available are quick-release, with the "snaps" (or whatever they're called) very close to the bottom of the bag, so they'd be easily visible/reachable. Do any of you know of a bag that either doesn't have the quick-release snaps, or has them in the middle of the straps, so they'd be on the underside of the seat? Or am I kidding myself, and this is a just plain bad idea?
Why do I want this? Because I wear a high-viz, armoured jacket when I ride, but when I'm running errands or going somewhere to spend time (dinner, shopping, etc.), I'd like to not have to wear or carry the jacket with me. It's heavy, not to mention obnoxious to look at.
This seat bag seems to be the perfect shape, and with new/different straps, could be easily modified to be what I'm describing (though it might not be big enough):
http://www.revzilla.com/motorcycle/wolf ... k-tail-bag
And I just ordered this roll bag to see if it might work with or without modifying, but it hasn't arrived yet:
http://www.revzilla.com/motorcycle/sadd ... e-roll-bag
Would love to know your thoughts/experiences! Thank you.
Re: Seat bag, tail bag, or roll bag that's NOT quick release
Posted: Fri Nov 01, 2013 1:15 pm
by DAB
Kermit wrote:Hi. I would love to attach a bag to my seat (I don't have a rack or any other mods), but I want it to be secure enough that I can leave it unattended and feel pretty confident that it won't be taken. (I would use a lock on the zipper for the bag's contents.)
1st one way too small, 2nd ???
David
Posted: Fri Nov 01, 2013 5:46 pm
by Darth Emma
Why not get a top case? It will do what you want and you can take them off pretty easily if you don't want it on your bike all the time.
Posted: Sat Nov 02, 2013 9:52 am
by Kermit
Darth Emma wrote:Why not get a top case? It will do what you want and you can take them off pretty easily if you don't want it on your bike all the time.
Yeah, I knew I would get that question, and I should have pre-empted it. I'm just not a fan of the top case, but I haven't 100% ruled it out. I was just hoping for something less obtrusive. I don't particularly care for the way the top cases are so
not integrated with the bike...they just look like a permanent afterthought to me, the way they sit so high and so far back.
Posted: Sat Nov 02, 2013 1:49 pm
by meissinger
Elsewhere, I have a thread with my combination saddlebags and top bag. The top bag does snap off too easy, but the saddlebags are strapped under the locked seat.
That said, however, my "high-viz, armoured jacket" easily fits inside the trunk, with my helmet hanging on the strap on the hook. If that's not an option, you'll need to do something else. I think the saddlebags I have will hold my jacket, though. I've used them to tote several sacks of groceries, sandals (when wearing shoes to ride), etc.
The forza will hold two helmets AND my jacket under the seat -- and the saddlebags and top bag transfer fine to the larger bike.
Hope that helps
Posted: Sun Nov 03, 2013 10:29 am
by Kermit
Thanks, meissinger. I'll look for your other thread.
Posted: Mon Nov 04, 2013 8:41 am
by maddiedog
Why not take a large duffle bag and just wrap the two handle straps under the seat, then lock the seat?
Posted: Mon Nov 04, 2013 12:17 pm
by Kermit
maddiedog wrote:Why not take a large duffle bag and just wrap the two handle straps under the seat, then lock the seat?
Yeah, that's pretty much what I'm doing, except that I didn't have a duffle bag, so I went ahead and ordered one made for a motorcycle. If the one I ordered works, I'll post pics.
Posted: Wed Nov 06, 2013 1:46 pm
by ahernandez74
You mentioned that you want it hard mounted though? It might take some custom modification to hard mount. Maybe try
http://www.vikingbags.com/explorer-seri ... ar-bag.htm and they're having a sale right now?
Otherwise, I would only be able to recommend maybe using a backpack and storing your stuff in there. That's the cheapest and quickest solution for you.
Posted: Wed Nov 06, 2013 1:54 pm
by Kermit
Not hard mounted...just secure. For hard mounting, it seems the only option would be a top case (or a bag mounted to a top case mounting kit). My issue is wanting something that's "on" the bike rather than "behind" the bike. Easier said than done.
I will likely end up with a top case. Just thought I'd ask this group if you knew of anything.
Posted: Wed Nov 06, 2013 6:24 pm
When we purchased our top box we didn't want one that looked too large or out of place, so we ended up purchasing one of the Givi smaller top boxes. It can only hold one helmet, but it blends in with the design of the bike. Another option might be to attach a backrest and attach a bag to it on the side closest to the rider. This would make it look like it belonged there.
Posted: Thu Nov 07, 2013 9:28 am
by Kermit
Mel, I like your idea of the backrest/bag combo, and it's one I've considered. As much as I like the idea, I think if I did it, I would end up hating it, simply because I'd have to remove the bag every time I wanted to open/raise the seat. Do you think your small Givi top box would hold a layered, armoured jacket (think "winter coat")? I know myself, and if I were to get a top box, I'd probably end up getting a larger one, which would give the exact look I'm trying to avoid. I'm getting close to landing on "who cares...get what you need..."
Posted: Thu Nov 07, 2013 9:45 am
by Darth Emma
Kermit wrote:Mel, I like your idea of the backrest/bag combo, and it's one I've considered. As much as I like the idea, I think if I did it, I would end up hating it, simply because I'd have to remove the bag every time I wanted to open/raise the seat. Do you think your small Givi top box would hold a layered, armoured jacket (think "winter coat")? I know myself, and if I were to get a top box, I'd probably end up getting a larger one, which would give the exact look I'm trying to avoid. I'm getting close to landing on "who cares...get what you need..."
You could always leave the top box home when you don't need it. They come off pretty easily with the key.
I've had the same thoughts you have about the top box. I don't like the look of most of them. I might get a Givi though and only put it on the bike when I know I'll need it.
In the meantime, I have a couple of "Rok Straps" (bungee-type straps, but nicer and won't scratch my bike) to hold a bag to the seat if I need to carry something that won't fit under the seat. But, it isn't secure.
