Page 1 of 2
slight vibration at about 68 mph...anyone?
Posted: Thu Nov 14, 2013 11:31 pm
by MORON
Im am still in break-in...anyone getting or had a slight vibration starting at about 68 mph....feels like a loose belt or something of that nature...was wondering if it was part of the break-in process...
Re: slight vibration at about 68 mph...anyone?
Posted: Fri Nov 15, 2013 12:44 am
by Mgalutia88
you're feeling the rollers in the variator bouncing around. its similar to a rev limiter except you can change out your variator and weights to add another 10+ mph.
Posted: Fri Nov 15, 2013 3:29 am
MORON wrote:Im am still in break-in...anyone getting or had a slight vibration starting at about 68 mph....feels like a loose belt or something of that nature...was wondering if it was part of the break-in process...
Should you be doing 68 when running in?
There is a bit of a buzzing vibration at higher speed, both mine and the demonstrator I rode did it.
It was worse on the lower mileage demonstrator.
Nothing to do with the CVT, its what single cylinder engines do.
Posted: Fri Nov 15, 2013 4:14 am
by MORON
man I don't like it at all....from your experience this is normal vibration??? bummer....so if I change the sliders like i did on my PCX (dr sliders) I can get rid of this??? which sliders to you recommend? thanks BTW for the advice....
Posted: Fri Nov 15, 2013 4:17 am
by MORON
gn2, I had a pcx which of course is a single cylinder motor and never had vibration...so I'm not buying the motor as a cause...unless there is a loose motor mount or some sort of defect in the drive train...I was thinking a loose belt.
Posted: Fri Nov 15, 2013 4:25 am
Its normal for a single cylinder engine to vibrate.
Honda have done a very good job of isolating the vibrations on the Forza, you should try a CBR250....
Without actually riding your Forza there's no way to establish if what you are experiencing is the normal slight buzzing vibration or something worse.
Take it to the dealer and get them to check it out.
The PCX has much smaller moving parts, so creates less vibration to deal with.
How many different motorcycles/scooters have you ridden over the years?
Posted: Fri Nov 15, 2013 2:15 pm
by ~Cheap_Ride~
Weird, My CTX700 doesnt have any vibration at cruising speeds up to 75.
Posted: Fri Nov 15, 2013 2:26 pm
~Cheap_Ride~ wrote:Weird, My CTX700 doesnt have any vibration at cruising speeds up to 75.
Must be a very different beast to the NC I rode, it was fucking awful.
Posted: Fri Nov 15, 2013 4:52 pm
by DAB
CTX=2 cylinders
Forza=1
Totally different machine.
OP claims a slight vibration? not really sure what that is, all my bike have a slight vibration.
Posted: Sun Nov 17, 2013 10:56 am
by Darth Emma
I'd take it to the dealer and see what they think.
Posted: Mon Nov 18, 2013 4:43 pm
by MORON
yea I had a pcx 150 with dr sliders...zero vibration and an awesome machine....just a little under powered for me. taking the forza to the dealer.
Posted: Wed Feb 12, 2014 5:32 am
by V4 TRV
Any updates?
I'm more than happy with mine and love the smoothness of the engine - should loosen up even more in the next 600 miles.
Posted: Wed Feb 12, 2014 11:00 am
Mine has done about four valve thousand miles now and the slight vibration circa 68mph has definitely decreased.
Posted: Wed Apr 02, 2014 6:17 pm
by alan
hi new member alan I also have a vibration at around 70,i think its not bad so I don't worry about it,dosnt seem as bad as I get more miles.
Posted: Wed Apr 02, 2014 10:29 pm
Mine has nearly 6000 miles and the 70mph buzz has reduced significantly.
Posted: Fri Apr 11, 2014 6:48 pm
by MrSuperchicken1
I am just under 600 miles and have also noticed this "buzz" type of vibration at around 67 mph. I find it to be a little erratic, but not sure if it connected to a certain rpm, or what. I know with the PCX, it had a limiter at about that speed, but do I understand that the Forza does not have a limiter? It just puts out all it can and that is it?
Thanks.
Posted: Fri Apr 11, 2014 7:51 pm
by AustinPCX
Over 4000 miles almost all of it 65-70 mph, no vibration for me.
Posted: Tue Apr 15, 2014 5:51 am
by marley2011
Didnt know pcx went that fast presume yoour talking about the 150 .? As the 125 would be max surely.
Posted: Tue Apr 15, 2014 12:34 pm
by AustinPCX
marley2011 wrote:Didnt know pcx went that fast presume yoour talking about the 150 .? As the 125 would be max surely.
Not sure who this was directed to but I have a Forza.
Posted: Tue Apr 15, 2014 9:30 pm
by willajabir
Might have confused him (he is new here) by your fuelly post in your sig & your forum user name......
Several upgraders/converts since the forum started as PCX focused.
