Tire Comparison?
Posted: Tue Dec 31, 2013 12:43 am
by Shar Tahl
I see a few tires recommended for best wear. Michelin City Grip and Pirelli Diablo are two I have seen mentioned a lot. What would be the best buy for a fair amount of distance travel.? I currently put about 200 miles a week on my scooter.
Re: Tire Comparison?
Posted: Tue Dec 31, 2013 5:50 am
I doubt there will be many people who have tried a variety.
I know from experience that the CityGrip rear is a safe bet.
The original front was still on mine when I sold it at 18000 miles.
Posted: Wed Jan 01, 2014 11:06 pm
by henrydjunaedi
I had to change my rear tire because it wore out. I came into the shop, they only have pirelli diablo scooter 120/70 available, originaly for front tire. The mechanic suggests it's ok to put it on rear, but the rotation must be inverted. So now, they're installing a front tire on my rear, backward rotation.
I wonder if it's safe. The mechanic seems pretty convincing, and he said he already done that in two other PCX.
What's your opinion?
Posted: Thu Jan 02, 2014 12:21 am
by henrydjunaedi
so far, it feels very good, i have great confidence riding my pcx to the corner.
Posted: Thu Jan 02, 2014 5:46 am
henrydjunaedi wrote:What's your opinion?
The mechanic was either lying or an idiot.
Posted: Thu Jan 02, 2014 11:37 am
by dasshreddar
henrydjunaedi wrote:I had to change my rear tire because it wore out. I came into the shop, they only have pirelli diablo scooter 120/70 available, originaly for front tire. The mechanic suggests it's ok to put it on rear, but the rotation must be inverted. So now, they're installing a front tire on my rear, backward rotation.
I probably would have kept the rotation the same, but as long as you don't get weird wear patterns you should be fine.
Posted: Thu Jan 02, 2014 1:02 pm
by OriginalRocket
Flipping the rotation is bad for a motorcycle tire, They are layered in a specific way due to the rotational forces. Motorcycle.com has an article about this. It could make a tire come apart!
As these are scooter tires, they are pretty simple in design. So I don't think they will fall apart. But reversing the direction of rotation seems very pointless to me as you are now losing any water drainage function from the tire.
BUT>>>... the mechanic might be aware of the tire layering, as the front is designed to take the braking force, and the rear to take the engine acceleration forces. So by switching the rotation, the force applied to the tire would be in the direction the tire was designed for.
Either way. These tires are super cheap, just replace with new.
Posted: Tue Jan 07, 2014 9:11 pm
by henrydjunaedi
thanks, i will buy a new one for the rear. and switch it to the front where it's originally intended.
this tire already improved my whole performance, acceleration, cornering, fuel economy. so, maybe next month. so yes, this pirelli is good and worth the buy. but they actually not very cheap for me. it's the most expensive scooter tire, and almost the same price as one tire for a car.
Posted: Fri Jan 10, 2014 11:57 pm
by redwind
I use the Dunlop Scootsmart. Much more stability and grip that the stock IRC tires.
Posted: Sat Jan 11, 2014 1:59 am
by FritzPinguin
