Has anybody mounted a GPS on there forza
Posted: Mon Mar 03, 2014 5:50 pm
by Forza 300
We're did you mount your gps and did you hard wire it ? I know there are some handlebar mounts I'm not sure if they fit properly ,if so What brand of mount did you use. Ram makes some nice ones,
Re: Has anybody mounted a GPS on there forza
Posted: Mon Mar 03, 2014 6:17 pm
by willajabir
I used this and mounted it in the center of the bars:
http://www.ebay.com/itm/Motorcycle-Bike ... 27cb34170a
Posted: Wed Apr 02, 2014 4:11 pm
by geotreker
Forza 300 wrote:We're did you mount your gps and did you hard wire it ? I know there are some handlebar mounts I'm not sure if they fit properly ,if so What brand of mount did you use. Ram makes some nice ones,
http://www.slipgripcarmounts.com/SlipGr ... 38025.html
I use the above on the Forza with my phone as GPS and i keep a 2A charger in the accessory socket with a mini USB cable at all times
Posted: Mon Apr 07, 2014 6:25 pm
by Forza 300
Ok found a ram 1" rubber ball mount that screws into one of the handlebar hold downs all you have to do is remove one bolt and install the ram ball and use one extra long bolt supplied with the mount ,screw it in then use a ram mount arm and attach to GPS using another ram mount 1" ball mount plate super easy and no damage to your bike and can be removed just as easy . The ram mount ball is part number ( ram-B-367U) go to there web site to see different arms as they have different lengths ,and different mounts for different gps .
