Leaking fuel 2013 150
Posted: Sun May 11, 2014 8:25 pm
by jonestownpadude
Rode my 2013 about 15 miles to the store (on a divided highway going about 50 mph). I filled up with fuel and then went into the store. I came out from the store and saw a small puddle of fuel underneath the pcx - actually then saw it leaking. Had some trouble starting, but it ran for 20 seconds across the parking lot and then died. I let it sit for 10 minutes then started it up. It was fine on the trip home (tried to keep it under 40 mph). I've got about 700 miles on it and just did the first service. It's in perfect shape otherwise. Any ideas, or has this happened to anyone else? Fuel pump? It's still under warranty, so I am hopeful it will be covered (it should be right?). Thanks!
Re: Leaking fuel 2013 150
Posted: Mon May 12, 2014 12:39 am
by iceman
Did you over-fill it? Perhaps it was extra fuel dripping out of the over-flow pipe as you say you it was fine on the trip home. Did the leak stop with almost a full tank left?
Posted: Mon May 12, 2014 1:38 am
by Alibally
That's what I thought as well
Posted: Mon May 12, 2014 7:19 am
by jonestownpadude
I may have overfilled it, but I didn’t think I did. Maybe it was hard to start and stalled because it was flooded? But it worked itself out when I let it sit for a few minutes. It was fine on the trip home and didn’t leak anymore overnight. And it started right up this morning, so that must have been it.. Thanks!
Posted: Mon May 12, 2014 10:11 am
by Slickvic
jonestownpadude wrote: Maybe it was hard to start and stalled because it was flooded? But it worked itself out when I let it sit for a few minutes.
Flooding usually only happens on carbureted bikes. If this is a fuel injection related issue then please take it to your dealer to troubleshoot.
There not much technical assistance we can provide here as this is a brand new model.
Posted: Mon May 12, 2014 10:15 am
by kramnala58
You might want to try filling it again and checking for a leak in case you have a broken seal up high on the thank. The other thing is, did you fill it full and then park in direct sun? It it was full enough, the heat may have expanded the fuel just enough to make it overfull and there was some sort of pressure release, although I would be surprised if that is the case because I believe the fuel pum relies on pressure in the tank.
Posted: Mon May 12, 2014 10:22 am
by wei2go
Has anyone found a solution other than buying a mccuff? Our gas attendants fill up the gas for you here in SA, and I feel like I'm screaming at him every time I shout out a warning when they're about to overfill.
Posted: Mon May 12, 2014 12:11 pm
by Slickvic
wei2go wrote:Has anyone found a solution other than buying a mccuff? Our gas attendants fill up the gas for you here in SA, and I feel like I'm screaming at him every time I shout out a warning when they're about to overfill.
Yes. The recommended solution here in North America is to always park the scooter on the center stand before filling.
The fuel tank will be level and the attendant should be able to better detect when the fuel level is near full.
Posted: Mon May 12, 2014 12:35 pm
by jonestownpadude
Thanks everyone. It wasn't in the sun right after I filled it - and I was only in the store for 10 minutes. The stall and trouble starting right after the leak is a concern. I'll call the dealer and take it in. Better to do so while it’s still under warranty!
Posted: Sun Aug 30, 2015 8:48 pm
by Jquinones961
any updates to this post? I had the same issue today
Posted: Mon Aug 31, 2015 3:39 am
by iceman
Slickvic wrote:jonestownpadude wrote: Maybe it was hard to start and stalled because it was flooded? But it worked itself out when I let it sit for a few minutes.
Flooding usually only happens on carbureted bikes. If this is a fuel injection related issue then please take it to your dealer to troubleshoot. There not much technical assistance we can provide here as this is a brand new model.
You can flood the PCX - the owners manual even has advice what to do should that happen and it did happen to me as I did not hold the rear brake in enough and tried to start the PCX a few times (kicked over but not enough) and then would not start, even 30 minutes later allowing for fuel to drain. I then read the owners guide, followed the 'flooding' section and the bike started just fine and has worked perfectly ever since (I always hold the rear brake lever in enough now).
Posted: Mon Aug 31, 2015 11:08 am
by j.d.b.
I'll look in my manual after work and post back, but generally, on modern cars, holding the throttle fully open while cranking is the procedure to clear a flood. If the cal. is like the cars, the fuel is shut off if the controller sees full throttle at cranking. This gets air through the wet cylinder/spark plug to dry it up enough to fire. Hope this gets you going for now.
Posted: Mon Aug 31, 2015 3:40 pm
by j.d.b.
Yes, in the O.M. I see it has the "clear-flood" procedure of a normal F.I. system. "Open the throttle fully and crank for five seconds", then try a normal start, again.
Posted: Mon Aug 31, 2015 8:35 pm
by iceman
j.d.b. wrote:Yes, in the O.M. I see it has the "clear-flood" procedure of a normal F.I. system. "Open the throttle fully and crank for five seconds", then try a normal start, again.
Yep, worked for me! I was beginning to panic as it looked like I could not get it started again (due to not holding in the rear brake lever enough for the bike to properly start). Using this procedure, found in the owners manual, worked like a charm but took a few goes (it does say repeat if needed). Of all things in the owners manual, this little gem is worth knowing.
Posted: Tue Sep 01, 2015 9:38 am
by j.d.b.
I've studied the shop manual at length and I don't see how the thing can leak fuel on the ground barring spilling fuel in the rubber bib that surrounds the filler neck. I have read, but it's not clear to me how overfilling can leak out the evap. System. It does look as though one could get fuel into the canister and damage it by over-filling and getting enough fuel into the vent line off the filler neck. Still curious about those reported leaks. Anyone else?
Posted: Mon Sep 07, 2015 2:36 pm
by Jquinones961
a Harley guy told me the other day there is a release valve in the next of the bike and when it's hot out it can leak out bottom of bike (left side feel underneath.. by kickstand)
