MIL lamp check codes
Posted: Wed May 14, 2014 5:18 pm
by mbbrzoza
Hi,
I have a problem with my PCX. After warm-up, lights up the MIL.
The MIL flashes one long and one short, then a pause, and again the same sequence...
I would add that it does not work Stop-Start system.
My PCX is 125 from 2011
Best Regards
Marcin
Re: MIL lamp check codes
Posted: Thu Aug 28, 2014 11:20 pm
by schiise
happens to me too. can't seem to find the answer to it. even my mechanics.
Posted: Fri Aug 29, 2014 12:30 am
by iceman
For those with service manuals, are the warning flashes not covered in the manual? Ordered mine for the 2015 model, but it's not with me yet so interested to know if it covers everything or some things only for dealers to know with their 'ECU' testers.
Posted: Fri Aug 29, 2014 12:49 am
by iceman
Can't edit my post now, so here's a link to a service manual for another honda bike that has PGM-F1 info and error code defintions - it may help!
https://docs.google.com/uc?export=downl ... ey=COCj8n8
Posted: Wed Sep 03, 2014 2:12 pm
by maddiedog
MIL lamp check codes are outside my scope. Take it to a dealer.
Posted: Wed Sep 03, 2014 3:52 pm
by iceman
My 2015 shop manual ammendment says that code is to do with the MAP (manifold absolute pressure sensor) and some causes are: low voltage (less than 0.21v) which may be due to a multi-way connector issue (re-seat), faulty MAP sensor or ECU issue. These units and connectors may not be easy to get to and involve lots of dismanting.
As maddiedog suggests - it may be wise to pass it by a dealer and ask their advice.
